Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 89
Thread: 2007 Mini Cooper Project
  1. #71
    Apr 2008
    sorry one last question for you. so i soldered wires onto the switch and for no am going to just press a switch to turn on the eeepc. ive noticed that you cant do this unless the lid is open. i was wondering if you by anychance knew where the lid switch is so i can trip it and make it think that the lid is always open. Thanks in advance!
  2. #72
    Constant Bitrate lacning74's Avatar
    Apr 2008
    my eeepc 900ha had a magnet (that i removed) in the screen's bezel used for sensing if the lid is closed.
    this pic is from this eeeuser thread:
  3. #73
    Apr 2008
    so if i remove that magnet, it will think the lid is always open?
  4. #74
    Apr 2008
    Quote Originally Posted by moelsaied88 View Post
    yup. unfortunately, that's the only way i know of to be able to turn on the closed laptop with the power switch.
  5. #75
    May 2004
    Denver
    any pics of the mimo screen installed in the headrest??
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
  6. #76
    Apr 2008
    Quote Originally Posted by mgithens View Post
    cut a little to much fabric but don't think my toddler notices. wish there was an official headrest shroud. also, the mini cooper has the smallest head rests.
  7. #77
    Jun 2008
    lacning74 - How are you powering the LCD now? Using the secondary 12V?
    Also - regarding soldering the ACPI wires to the power button, does it matter which lead I solder the green and white wires too or is there a specific +/- on the power button leads? Thanks!
  8. #78
    Apr 2008
    Quote Originally Posted by noobified View Post
    right now, i'm just using the a wire tapped into the my car's fuse, basically just like using the cig lighter. reason being, the image is fine, actually brighter, and i'm not going to obsess about long term screen life. if my carnetix acts up again, i don't want to have to re wire the screen just to use my back-up cam and dashcam.
    as for soldering, it doesn't matter which one. it's just a relay that completes the circuit.
  9. #79
    Apr 2008
    well, i don't know why i didn't try this earlier, but i set my Carnetix 2140 on standby mode. now i got instant resume.
    the Carnetix 2140 will keep power going to maintain standby as long as the current draw is less than 0.5amps and the car battery level is good. i wasn't sure if it would work with my laptop since it draws too much power when plugged in with the laptop's battery to maintain it's charge. i thought of just letting the laptop battery maintain standby, but the laptop battery quickly drains overnight.
    well, i removed the laptop battery, and standby mode works! interestingly, while the laptop was on, the amp draw (as monitored by the PSUmoni app) dropped from around 3 amps to just 1.1 amps after removing the battery (my usb monitor was not plugged in). i was wasting power by keeping my laptop battery in for all this time.
    i'll see if standby holds up well this week. this better justifies the use of my "intelligent" Carnetix.
  10. #80
    Apr 2008
    hey lacning could i trouble you for one last bit of help? i just ordered a Directed 528T Pulse Timer with SPDT Relay and i was hoping to get some advice from you on how to hook it up. if you by any chance have some pictures of what you did or anything at all i would greatly appreciate it. thanks in advance!
  1. Replies: 17
    Last Post: 04-23-2009, 03:36 AM
  2. CPU location for Mini Cooper
    By sycophant in forum General MP3Car Discussion
    Last Post: 08-01-2008, 07:51 AM
  3. 1984 Austin Mini Carputer Project
    By bobjimwilly in forum Worklogs
    Last Post: 11-12-2007, 08:07 AM
  4. Pc Mini
    By fungke in forum General Hardware Discussion
    Last Post: 06-02-2005, 05:43 PM
