Page 9 of 9 FirstFirst 123456789
Results 81 to 89 of 89
Thread: 2007 Mini Cooper Project
  1. #81
    Aug 2009
    Since you seeme to have been all over your assus eee. Would you mind helping with the placement of the magnet, or the magnetic switch for the lid?
  2. #82
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by moelsaied88 View Post
    hey lacning could i trouble you for one last bit of help? i just ordered a Directed 528T Pulse Timer with SPDT Relay and i was hoping to get some advice from you on how to hook it up. if you by any chance have some pictures of what you did or anything at all i would greatly appreciate it. thanks in advance!
    sorry, don't have the relay anymore since i upgraded to the Carnetix 2140. basically set it up pretty much like this guy used his for. set up like a standard relay to complete your computer's power switch leads. wire the ground wire and "trigger" wire together to a ground. connect red wire to your car's switched 12v. adjust the timer accordingly.
  3. #83
    Apr 2008
    Quote Originally Posted by eivinds2 View Post
    check post 72.
  4. #84
    Apr 2008
    well, i got some new parts, a single-din kit from Shokits and a sunlight readable Lilliput 701 with auto-back up switch wire monitor from Mo-Co-So. The Kanatech single-din kit is very impressive. The console piece is solid with amazing texture, better than OEM. The instructions are vintage Japanese precision with precise illustrations. Both the Japanese and English translations are included. Lots of wiring, harnesses and stuff I will not be using since I'm not replacing the headunit. If I did, the kit would certainly be worth $300 for sure. I can't wait to test out the monitor in the sun. I had to hack the double-din frame and rearrange the circuit boards inside in order for it to slide in the single din area while the top half would lie as flat as possible against the OEM CD player/volume knob area. The result will not be the prettiest but will be much more ergonomic overall in terms of visibility and access of the A/C controls/toggle switches vs my current install. Now I need to find some free time to install it in the car. :impatient:
    Here's some pics:
  5. #85
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by lacning74 View Post
    It appears to me that the work you did was way, way above the level of "hack". That looks excellent. You must mean "hack" as in "hacker", or "innovator".
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  6. #86
    Apr 2008
    Well, had another masochistic night getting this installed. I forgot I had a couple huge modules sitting in the single-din "space" from my NewMiniStuff bluetooth install. Somehow got everything to fit. Here's some quick cellphone pics for now.
  7. #87
    Apr 2008
    Here's a better picture of my console:
  8. #88
    Nov 2009
    I just wanted to say that this is most excellent and inspiring.
    Cheers!
  9. #89
    Sep 2008
    Western Australia
    Hey,
    I've searched your threads and Youtube videos, but haven't been able to find out if you solved your glare problem with your dashcam? I'm looking into upgrading my webcam to CCD camera, but I want to do this right and buy the right camera from the start.
  1. Replies: 17
    Last Post: 04-23-2009, 02:36 AM
  2. CPU location for Mini Cooper
    By sycophant in forum General MP3Car Discussion
    Last Post: 08-01-2008, 06:51 AM
  3. 1984 Austin Mini Carputer Project
    By bobjimwilly in forum Worklogs
    Last Post: 11-12-2007, 07:07 AM
  4. Pc Mini
    By fungke in forum General Hardware Discussion
    Last Post: 06-02-2005, 04:43 PM
