Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: 2009 scion xb mac mini
  1. #21
    Mar 2009
    Thanks for the pics. I wonder...
    Thanks so much for posting the pics. It's great to see the work in the flesh (so to speak). I'm really excited to see any more pics you can upload (mini mount, daytime LCD screen shots, cabling, etc). I wonder if you wouldn't mind answering a few initial questions for a newbie.
    1. Did you do any fabrication to get the screen to fit in the place of your old head unit? Or is it just mounted behind the original faceplate? You had mentioned having trouble getting it flush with the dash, were you able to resolve that?
    2. How much dismantling of the console did you need to do to route the cables? Did you need to take apart the console between the seats as well as the front console? (If you've got any pictures of the process, that would be AWESOME!)
    3. How do you find the viewability of the 701 during the daytime? I know some LCDs don't do well in direct sunlight but I would think in the xB it wouldn't be too hard to see it in the daytime.
    4. Now that you've completed the process (or almost?), do you have any key tips for me as I begin the process (pitfalls to avoid, things you wish you would have done, odd things about putting it together in the xB, etc).
    Again, thanks for the pics so far and for any advice you can give. I REALLY appreciate your time and effort.
    Jim
  2. #22
    Constant Bitrate scatebase's Avatar
    Oct 2008
    Quote Originally Posted by jrispin View Post
    It basically just mounts right behind the original bezel. The problem I had was that the screen is a little too tall and keeps the bezel from going back on completely. Most people don't even notice, but it bugs me. I want to try and fix, but I haven't had the time.
    The bezel around the screen, the silver around the shifter, the black below the shifter, the entire center console. It is very easy to take apart and put back together. I think there are only 3 screws in the center console and everything else just pops off.
    I have been happy with the screen. I don't think there has been a time when it was unusable because of glare. During the day it doesn't look as bright and the colors aren't as bold, but it is definitely usable.
    So far I don't think there is anything I would do differently. Other than the screen not fitting, everything went in easily and has worked well. I can't think of any tips to give you that are xb specific, but I have learned plenty of carpc specific tips from this site. There are a bunch of people on this site that know what they are doing and have tons of experience, and this site is a great place to learn from their mistakes. The best advice I can give you is to continue to be part of this community and contribute your ideas and knowledge.
    If you have any other questions, feel free to ask. I hopefully will get some more pictures up soon.
  3. #23
    Mar 2009
    Another quick question. I had read that the Lilliput display was slightly narrower than the double-din space in the xB, leaving a little space on either side of the screen. Is this accurate and if so, what did you use to bridge the gap? Thanks.
  4. #24
    Oct 2008
    The gap is about 3/4" inch on each side. I used a double din dash kit from crutchfield to fill in the gap. Eventually I want to use some fiberglass to make it one flush piece.
  5. #25
    Oct 2008
    Finally!!
    I've got some good pictures and some updates.
    I recently bought a Phoenix Soho to help with echo cancellation after I read this thread. I am still putting together a lexan case for it and I will put up a post later with more details.
    I also figured out how to make my dash bezel sit flush and look halfway decent. It was actually pretty easy and I'm happy with it. It really makes this whole project seem more legit. All I had to do was cut a small part of the OEM bracket off and adjust the bracket to make it sit flush.
    And here are the pictures:
    Here are the two tabs I had to cut on the OEM bezel
    This shows how the bracket went together to make it sit flush. If you want more info on that, let me know.
    And here are the pics with glare. This is about as bad as it gets and it doesn't really bug me much; it is still usable.
  6. #26
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Nice job man, Im planing to switch from PC to MAC in my car, it looks much more stable, and ICE3 looks like what I needed since the first day!!
    Question: which GPS software are you using? How the mac react to an hibernation, does it come back well or some features are missing just like windows...??
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
  7. #27
    Oct 2008
    Quote Originally Posted by VmtSquad View Post
    For GPS I had hoped to use roadnav, but I have had trouble with it. It crashes shortly after launching it. I posted a thread about it, asking for help, but still no response .
    I have been really happy with hibernation on my mac mini. It wakes up fairly quickly and my battery hasn't died yet.
  8. #28
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Did you see my old 08 XB carPC i built last year?
    http://itloser.homeip.net/carpcvids/xb/Xb_carPC/
    2008 Scion xB
    10 acura TL tech
    10 BMW S1000RR
  9. #29
    May 2007
    Any news on a GPS solution for us MacCar users ??
    Final Install
    CarPC progress: 95%
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  3. 2005 Scion xA- Mac Mini
    By Doomspat in forum Worklogs
    Last Post: 11-27-2006, 10:07 AM
  4. 2 x 2006 Scion xB + Mac Mini (Intel)
    By TnT_xB in forum Show off your project
    Last Post: 05-07-2006, 11:17 PM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
Tags for this Thread
