Page 18 of 86 FirstFirst ... 891011121314151617181920212223242526272868 ... LastLast
Results 171 to 180 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #171
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Not enough juice thru the regular PSU?
    Tidder
    Try RevFE
  2. #172
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Tidder View Post
    Thats what I was going to say. The OPUS is very defensive about the juice coming into it. If its even one watt below what it requires, it will not turn on because it thinks your battery is low. What wattage OPUS did they send you?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #173
    Sep 2003
    New Mexico, USA
    I think it was a 120.
    Tidder
    Try RevFE
  4. #174
    Jul 2007
    Miami
    I have a PC from like 7 years ago and it uses a 150 watt supply. Did you read the manual from OPUS? They have it online at http://opussolutions.com. Maybe a jumper is set incorrectly.
    WAIT WAIT WAIT...... stupid me not asking the right questions. What type of blink is it. If its a steady blink of 2 seconds apart, then it means it is getting good power. If its 2 bilinks back to back followed by a pause, then something is wired wrong. Check to make sure you connected the cable to the MoBo on switch header correctly. Maybe you have it backwards?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #175
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Idk if it's getting enough power or not. The light is blinking once every 2 seconds. It's an Opus 120. Saul and I are hacking the case up right now so it'll fit underneath my seat. I'll post pics when I get home.
    Project λ^2 (Lambda Squared or Lambda II)
    [☺☺☺☺☺☺☺☺] Install 80%
    Saving $ for PSU
    Coming soon: freeflashstuff.net
    It will be my business site, and it will also have a section dedicated to my previous and current builds.
  6. #176
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    Then you must have wired the switch to the MoBo wrong. The steady blink means its getting enough power and working as it should.
    Trouble shooting guide
    Computer does not turn on?
    Check to make sure that battery and ON-OFF pins are connected to DC-DC Power Supply connector.
    Computer does not turn off when the ignition is turned off!
    Check the Green LED state Interpreting the Green Status LED light flashing 0.1 sec ON and 5 Sec OFF Approx.: DC-DC power supply is in Idle or stand-by state. On constantly The PC is powered and the PC should be operating.
    Error Flashes Reason
    1 Flash Battery voltage is below normal operating range.
    (every 10 Sec.) Voltage set by JU1 – 4, 5
    2 Flashes The computer power up sequence failed. Reasons:
    • Check the wiring of the two wire power-switch cable from power supply
    connector J9 to power switch pins on the ATX motherboard. If connected
    properly check the polarity of the power switch pins, may be reversed.
    • Check ATX mother board bios settings.
    • Locked up motherboard or software crash.
    • Faulty DC-DC power supply.
    3 Flashes Power supply output voltages are out of normal voltage range. Reasons:
    • Power supply output is over loaded or shorted.
    4 Flashes Power down, stand-by or hibernate sequence failed. Reasons:
    • Check ATX motherboard bios settings.
    • Check if ACPI function is enabled in the power management BIOS setup.
    Make sure ACPI drivers are installed in the operating system.
    • Check if application is compatible with ACPI mode of operation.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #177
    May 2008
    Thanks HiJack.
    *ON TOPIC*
    The project is officially on a hiatus for the next couple of weeks. I have a dossier to put together by Saturday and my SAT to take Saturday. I need to get my ticket printed out and all my stuff together for that. Not to mention, school's almost over, but then summer college prep stuff starts the week after I get out of school.. Oh, well. Damned if I do, damned if I don't. I'll be able to use the collage Internet, though. *evil grin* Too bad I can't hack anything there...
    Saving $ for PSU
  8. #178
    Sep 2003
    New Mexico, USA
    Hey man, I'll be passing thru pretty close to your town on friday May 8th. I'm gonna head out to the TX meet I think, but will be stopping in Midland first to do some maintenance for a client. Wondering if you wanted to meet up and try to get some stuff done on your ride, if so I'll duck out of here early.
    Tidder
    Try RevFE
  9. #179
    May 2008
    I might try. Where are you going to be making stops? I think by that time, mom and I both will be needing a vacation... Did you get your psu today?
    Saving $ for PSU
  10. #180
    Jul 2007
    Miami
    Thanks HiJack.
    *OFF TOPIC* I am hosting files for people who need space. I can only offer 10 MB to about five people for a month. If you know of anyone who needs space, let them know and I'll see what I can do. On that note, I'm hosting an EP for a friend of mine's band, "White Lies and Photographs" to be released at midnight. The link to it will be posted on his band's MySpace page located at: http://www.myspace.com/brianclaytonmusic
    *ON TOPIC*
    The project is officially on a hiatus for the next couple of weeks. I have a dossier to put together by Saturday and my SAT to take Saturday. I need to get my ticket printed out and all my s**t together for that. Not to mention, school's almost over, but then summer college prep stuff starts the week after I get out of school.. Oh, well. Damned if I do, damned if I don't. I'll be able to use the collage Internet, though. *evil grin* Too bad I can't hack anything there...
    Well if anyone needs to host files, I run my own servers.... infact if anyone likes StarCraft, I have StarTrek Armada 2, which is StarTreks version of StarCraft. Ive been looking for people to play with me. You can download the ISO and then burn it and we setup a game. Being that said you can also upload files, just remember I run them from my house so my upload isnt fast. I run my own servers because with hosted servers I can put what ever I want. Im creating a TV station and it will have alot of bad language and nudity and most hosting doesnt allow the later.
    My project is also slowed to a crawl. I decided to rip out all of my audio system and start fresh with a monster system. That costs alot of money (I have to get a second job to pay for it) then im starting with the PC again. Im also selling my SSD, I cant figure out how to configure it and its giving me a headache. I may go back to HDD.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
