Page 19 of 86 FirstFirst ... 9101112131415161718192021222324252627282969 ... LastLast
Results 181 to 190 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #181
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    HiJack, the diagnostic blinks you sent show 3 blinks as overloading/shorting the output. Should a SATA HD and an Intel Atom board overload the Opus 120? Or do both of the 12VDC lines have to be hooked up to 2 different input lines? If it's 2 different input lines, then what size fuse should I use?
    Side Notes and Misc. BS of Life :
    I have to fix my A/C, it's leaking... I'm converting it from R12 to R134a tomorrow. Got a friend with the equipment to take the R12 out properly.
    I'm on Twitter!
    I have also been working on a portable development environment for SCC. It consists of Processing, Python 2.5, MIT-GNU Scheme, Portable JDK, NetLogo 4.0.4, Dr. Java, and some other stuff. It fits on a 2GB flash drive. If anyone wants to help me test this, PM me.
    Project λ^2 (Lambda Squared or Lambda II)
    [☺☺☺☺☺☺☺☺] Install 80%
    Saving $ for PSU
    Coming soon: freeflashstuff.net
    It will be my business site, and it will also have a section dedicated to my previous and current builds.
  2. #182
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    I'm on Twitter!
    You have to take all devices into effect. The 12V rail on the 120 can only handle up to 3.5amp max. The 5V rail can handle 8amps. It could be you are maxing out one of the rails?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #183
    May 2008
    I can unplug the SATA HD, and it still blinks 3 times. Surely the Atom doesn't overload the Opus 120
    Saving $ for PSU
  4. #184
    Jul 2007
    Miami
    You never know..... maybe its eating up all of the 12V amprage. How much does it say the Atom MoBo uses? Also, are you testing this in the car? If yes then set the voltage jumper on the PSU to 11V set it from jumper 5 (default) to jumper 4. It could be that your battery isnt strong enough.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #185
    May 2008
    Well, the Atom draws 45W total, so...
    I got my A/C system converted with a retro-fit kit from AutoZone, it blows a lot cooler now, and I was also able to fix the leaks it had.
    Saving $ for PSU
  6. #186
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Dude I totally failed this weekend at doing anything. I made it to Midland, TX for the job, but I missed the meet, didn't have time to touch base with you to meet up, etc. Bah.
    Tidder
    Try RevFE
  7. #187
    May 2008
    Tidder: That's cool, I totally forgot about it...
    Got the Opus 120 working, had to run 2 separate 12V lines to it. Now I need to figure out how to set the timer...
    Saving $ for PSU
  8. #188
    Jul 2007
    Miami
    @Tidder: That's cool, I totally forgot about it...
    (DAMN IT! I'M TOO USED TO TWITTER!)
    WHAT!!!!!!!!!!!!!!! Wait a minute.... What gauge wire did you have going to it? A 4 gauge wire should have been more then enough. Infact I am running a 8 guage to my OPUS 320. If this is happening your not using the propper gauge which can result in dangerous situations. If I am not mistaken all the yellow wires (3) should go to a 4 - 8 gauge wire. Then the grounds (3) should go to a solid ground point. Anything like 16 - 24 gauge is bad and can cause a fire if overloaded. I dont know why I didnt think of this before
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  9. #189
    May 2008
    I'm running 12AWG for now, just a temp setup until I can get everything sorted out.
    How do I go about setting the timer on the Opus 120?
    Saving $ for PSU
  10. #190
    Jul 2007
    Miami
    I really think you should use 8 or less. Thats not something you should half @$$. The electrical is the most important part of the install
    Go to http://opussolutions.com and download the manual.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
