Page 22 of 86 FirstFirst ... 12131415161718192021222324252627282930313272 ... LastLast
Results 211 to 220 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #211
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Quote Originally Posted by HiJackZX1 View Post
    OMG, and you painted over the super red? I'll take pictures of the guys car, his is also the 2 door version.
    I did not paint over the Super Red. The first owners did not like the Super Red, they said it was ugly so they had it painted over with its current color, BMW Green. Most of the details, like the trunk, are still the Super Red. (Why am I capitalizing Super Red? LOL)
    Quote Originally Posted by rdholtz View Post
    Tell your Dad I said Welcome Home -- both meanings.
    As for you -- welcome to summer!
    Done, done, and thanks...
    Project λ^2 (Lambda Squared or Lambda II)
    [☺☺☺☺☺☺☺☺] Install 80%
    Saving $ for PSU
    Coming soon: freeflashstuff.net
    It will be my business site, and it will also have a section dedicated to my previous and current builds.
  2. #212
    May 2008
    Your moving in all the wrong directions. I would address the engine issues first. No point in having a nice painted car, if you cant drive it at all. The main seal is so important, so is the alternator alignment. Fix the engine, then move forward.
    I found out from the old man(my dad for the noobz ) that it's gonna be about $1000 to fix the front seal, replace the timing belt, water pump, seal, and oil pan, I think he said. Alarm install will probably be Saturday, and engine to almost immediately follow.
    Saving $ for PSU
  3. #213
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    Yea to change a major seal like that takes alot of time. You have to take alot of the engine apart. Timing belt, and oil pan should be no biggie. The water pump maybe, depending on how it sits in the engine, most imports arent hard. Cant wait to see pix.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  4. #214
    May 2008
    There may not be pix if I have to put it in the shop rather than doing it myself or dad doing it. But Saul came to the rescue, yet again, with a source of the same paint for half the price! I found a kit with all of the parts I need for the repair: the timing belt, the timing belt tensioner pulleys, the A/C belt, alternator belt, timing belt tensioner spring, valve cover gasket with grommets, and front cam/crank seals for $150 shipped. I also found the oil pan gaskets and rear main seal for $40 on eBay. That's all the stuff the mechanic estimated to cost around $700, for around $200. That ain't bad. And there definitely won't be pix cause I have summer classes and dad has gotten really shaky and doesn't trust himself to do it. So there's about $400 in labor, but it needs to be done...
    Saving $ for PSU
  5. #215
    May 2008
    So many posts and projects, so little time...
    Sorry... had to say that before this. I was just talking to Saul about 10 minutes ago(forgot to mention in last post), and he suggested that since we have been having so many problems fitting the CarPC under my seat, to use the space that the glove box occupies for it. What do you all think?
    Saving $ for PSU
  6. #216
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    How much space is available in the dash? Is it double-DIN? How deep?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  7. #217
    Jul 2007
    Miami
    Here is what the interior looks like.
    Although the glove box looks big, it may not be big enough. What do your rear seats look like? Ever thought of making a center console for the rear?
    EDIT, never mind, doesn't look like there is a center console in the front, so it would look awkward. Take pictures of you entire interior, maybe you can do something like I am and putting the computer behind a body panel. Take pictures of the rear panels next to the passenger seats. Maybe the PC can be hidden behind one.
    That is the 98 interior, but I am sure yours is the same. See the area I high lighted, maybe the PC will fit behind there. Only thing is, you will have to get the PC running 100% and do everything on point. Otherwise you will have to take apart the panel all the time.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #218
    May 2008
    That panel is a PITA to take apart, not to mention, the case would be right against the exposed metal, meaning every bit of heat will transfer to the PC. But some kind of material could be put in there to take care of that. I'll take it apart later check it out and take some pix. I was stupid today. I skipped the last half of the last day of school(we were just playing cards in the commons area) to go swimming at a friends. We managed to give her little brother a concussion cause he wanted us to throw him in, but he's OK now. I, on the other hand, didn't drink enough water(like an idiot) and am now dehydrated and sunburnt.
    Saving $ for PSU
  9. #219
    Apr 2007
    Atlanta, GA, USA
    Good. Take pix and give me good dimensions. I have an idea, and they'll help me plot it out.
  10. #220
    Jul 2007
    Miami
    The panel is a PITA, but if you get the PC running 100%, you will never have to take the panel off in the first place. Maybe make a slide in type case, just loose the cup holders. I doubt anyone uses them. Also all you have to do is add heat padding to absorb the heat. My truck has it in major areas with alot of electrical wire. Seems to work great.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
