Page 3 of 86 FirstFirst 1234567891011121353 ... LastLast
Results 21 to 30 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #21
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I'm back from Lubbock as of Saturday and there is no school today, but the electricity in my house decided to go FUBAR and so I'm stuck helping my mother figure out WTF is wrong. If I get the chance, I'mm gonna mix up some resin and see if that will solidify enough to make the box what I want. Thanks for the idea rdholtz!
    Project λ^2 (Lambda Squared or Lambda II)
    [☺☺☺☺☺☺☺☺] Install 80%
    Saving $ for PSU
    Coming soon: freeflashstuff.net
    It will be my business site, and it will also have a section dedicated to my previous and current builds.
  2. #22
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by freeflashstuff View Post
    Good luck with the power problems. And especially good luck with the cardboard + resin project. If I wasn't leaving for a month on the road, I'd have grabbed some resin components and played with the same kind of thing, just to see what we'd get. I have high hopes for you . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #23
    May 2008
    I didn't exactly get a chance todya, but we did get the electrical problem fixed. It was a bad fuse socket... We don't have breakers because our house is so old... LOL
    Saving $ for PSU
  4. #24
    Apr 2007
    Atlanta, GA, USA
    I've had two houses with systems so old they still had screw-in fuses. I rented a house that had them, and just put up with them for a year. Then I bought my first house, and it had them as well. That place was built in 1911, and it had 30A service for the entire house; I couldn't use the toaster while my wife was using her hair dryer. One of my early renovations was to have new service (and a new breaker box) installed; then I rewired the whole house over the next year.
    If you look around, they make (or at least they used to make) circuit breakers that fit the screw-in fuse openings, and I think they are (were) available from 5A to 30A. They look like fuses, but each one has a little white button that pops up when it blows. Push the button down, and you're back in business. Then you get to go track down what's popping the breaker. Each breaker cost as much as a whole box of fuses, but they never needed replacement. I don't know if Home Depot carries them, but if you have an old-timey hardware store in the area, they probably have some.
  5. #25
    May 2008
    I found 15A and 20A but no 30A... Maybe the next time I go to Roswell I'll check at Home Depot. As for the box, I'm gonna try for tomorrow on a smaller, experimental box. If it comes out as well as I hope, mine will be done the same way, then maybe I'll paint it(???)
    Saving $ for PSU
  6. #26
    May 2008
    I PM'd Nexson, and he suggested that I used a wooden box instead of the cardboard and resin. I had planned on doing that if the cardboard thing failed...
    Saving $ for PSU
  7. #27
    May 2008
    Well, I got my Lilliput EBY701 in yesterday, and the VGA/USB cable is FUBAR. I'm pretty ticked off right now. It will display RCA video-in, but no VGA or touchscreen stuff works. The touchscreen won't even show up in Add New Hardware...
    Saving $ for PSU
  8. #28
    May 2008
    Bump... Has anyone else had this issue?
    Saving $ for PSU
  9. #29
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Did you check that little connector that goes to the screen? Maybe you bent the pins or something? I have 4 Eby701s and non of them have that issue. If its not the connectors, then something happened to the main circuit board. If the screen is opened, try examining it and looking for burn marks, maybe you piut the wrong polarity to the screen and fried the part that allow you to switch, which is also connected with the touchscreen controller.
    Also check the small ribbon that goes from the button panel to the main control board.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  10. #30
    May 2008
    I checked the pins and they were all OK. I called Lilliput, and they are sending me a return label so I can get a new one. We'll see what happens.
    Saving $ for PSU
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
