Page 37 of 86 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #361
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Those fans should be fine. I'm in the middle of a fan test on mine with the same mainboard. The two 40mm fans are 12V units plugged into the 5V fan header on the M4-ATX, so they're really not pushing a lot of air out of the case. It's been going for 8 hours, and the exhaust air from the fans is barely above room temperature. If they need more juice, I'l hook them to 12V, but that appears unnecessary for now.
    The next test will be in operation; they're idling, right now. I suspect your fans will be way more than enough, but it's hotter in New Mexico than in Georgia.
    I can't help with the CF issues -- no experience here.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #362
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    Got my CF drive to boot, but it's hella slow. WTF is with that? It's been 3 minutes, and it's still loading...
    Honestly, when you have the fan system installed, the HDD over heating issue should be gone. Infact, since you have so much room in the PC's home, maybe mount the HDD on the outside of the case, just to be safe. That way if the inside of the case does overheat, the HDD is not near it. For about $24.00 you can get a new SATA 40GB drive, that includes shipping. I know people have done the CF thing, but I prefer to go with what works. So HDD in my opinion is the best way to go.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #363
    Jul 2007
    Miami
    I set everything up earlier today, I'm just waiting on the copying to my CF card to finish. Estimated 55 minutes left. Hopefully it'll boot after this is done... Ordered the fans too. I ordered two 80mm, 2700RPM fans from NewEgg. Hopefully they will be here at the end of next week. I'm also working on getting power to my USB hub in the front so I can have extra USB ports for flash drives, cameras, etc. I'm gonna use the (I think it was HiJack's) idea of getting the 5 VDC from the Opus, but I think I'm gonna throw a diode in there so I don't get power feeding back to the computer...
    The fans will be perfect. As far as feedback, I doubt you will have any. If you want to take that precaution though then its fine, I think... I have never heard of that being done on a PSU rail before.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  4. #364
    Jun 2009
    Katy, TX
    This is something I might actually be able to help on. Looking up CompactFlash cards on Wikipedia shows that it is quite possible that you have a low speed drive which could severely slow down boot times. I don't remember what board you have, but if you have the option to use SATAII and are still looking for a non-magnetic drive, take a look at the OCZ Vertex Series, particularly this one. It's certainly a bit pricey compared to standard drives, but lower power consumption = less heat, no moving parts, and faster than some of the best high-speed magnetic drives. For an absolutely great overview of solid state drives, look at AnandTech. The March 30 article is what got me really excited about OCZ and the Vertex series. While I'm pretty far from starting my carpc project, I am planning on using this (unless something better comes out by the time I start) as my OS and applications drive.
    Alternatively, you could use a new magnetic drive exactly like Hijack said since you may have solved your heat issues.
  5. #365
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Could be that the CF to IDE adapter you have doesn't support DMA... link to what you bought? Also, what CF cards did you buy?
    Tidder
    Try RevFE
  6. #366
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I solved the problem. I had a drive letter confusion that was causing EWF to re-map the drive on every reboot. My C drive was showing up as D and I couldn't get to diskmgmt.msc because "it didn't exist." I booted into UBCD for Windows and cracked open the registry as shown here: http://tech.kdcad.com/?p=157 and solved the problem. I now have a boot time(to desktop) of about 25 seconds +/- a few seconds. 35 seconds to Centrafuse loading up fully. Now i just need to tweak Startup entries and Services
    Quote Originally Posted by Tidder View Post
    I bought this adapter on eBay: item # 290291693302
    The cards:
    32GB(30GB really) one like this one from same seller minus the bonus BS: 260369606720
    16GB(15GB really): 220356501505
    The cards were oringinally purchased for use in my iPods, but I fried the logic board on the one I bought the 32GB for, and accidentally bought two 16 GBs for the one I sold. (Buy It Now, and I put in a Best Offer, and won both... DOH!)
    Project λ^2 (Lambda Squared or Lambda II)
    [??????????] Install ???%
    Defecation hit the oscillation
    I have no clue what's going on anymore!!!
    Coming soon: freeflashstuff.net
    If I have time, I'll update it. College is a pain in my arse.
  7. #367
    May 2008
    I hope everyone had a pleasant 4th of July weekend. I did. I actually got some work done on the Turtle. I installed my electronic flasher to solve my "ricer flash" problem. I also installed my LED dome light and LED lights to illuminate my floor boards in the dark. Last night, I left my headlights on and had a dead battery this morning, now the CarPC won't boot... It powers on for a minute, then shuts off. The Opus blinks 3 times. I think that's the low voltage blink, right(HiJack)?
  8. #368
    Jul 2007
    Miami
    OMG, I FORGOT TO SEND YOU OUT THE FLASHER THINGIES, MY BAD!!! Do you still need them?
    You are correct, to low a voltage. Im suprised it turns on at all, it should just start blinking the 3 times and avoid trying to boot up the PC. Your battery must be borderline on the low voltage that tells the OPUS to not turn on and warn you. Just drive around for a day or so with no PC on, so the battery can charge back up, unless you have a charger and charge the battery.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  9. #369
    May 2008
    No, I don't I just got an electronic flasher from AutoZone. The resistor mod doesn't work for a stock Tercel flasher, because the flasher expects a WAY higher resistance then they supply, plus with the electronic flasher I can do all of my lights LED and not have to mess with equalizers on all of them. I think I'll just steal the battery out of my mom's Chevy pickup, it's the Wal-Mart equivalent of an Optima Yellow Top... LOL
  10. #370
    Jul 2007
    Miami
    You cant just use any battery in a car!!!!!!!!!!!!!!!!!!!!! If it isnt made for your car then it may damage it. Especially if its out of a big @$$ truck which is most likely a V6 or even a V8. Just drive the car around with no PC and charge the battery using the alternator.....
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
