Page 45 of 86 FirstFirst ... 353637383940414243444546474849505152535455 ... LastLast
Results 441 to 450 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #441
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    I think it'll handle up to 4GB, but there is only one slot.
    WOW, I would go for that then... Mine uses Laptop RAM so I have two 2GB sodim. The new boards I am getting only support 2GB because it can only take 1 stick of Sodim RAM.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #442
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Quote Originally Posted by rdholtz View Post
    You're running the Intel D945GCLF2, right? That's 2GB max.
    Project λ^2 (Lambda Squared or Lambda II)
    [??????????] Install ???%
    Defecation hit the oscillation
    I have no clue what's going on anymore!!!
    Coming soon: freeflashstuff.net
    If I have time, I'll update it. College is a pain in my arse.
  3. #443
    May 2008
    *scream of anger* I think I'm gonna have to redo my CF card. Now that I've put it back in the car, it's rebooting every 10-15 minutes. I even went back to CF from RR to see if that would please it(I was going to anyway... Couldn't get XM to work, and as my friends know, I loves me some XM...). But I'm definately staying with CF. RR is way over my head time wise.
  4. #444
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    . . . But I'm definitely staying with CF. RR is way over my head time wise.
    That was exactly my experience. I beat my head against RR for days, and finally installed the 30-day trial of CF. Including the time it took me to read through the CF documentation, I was up and running in a few hours. This last install was less than an hour of relaxed configuration, and it probably would have been 10 to 15 minutes if I'd given it my full attention.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  5. #445
    May 2008
    My only gripe about CF is the lack of skins that I like. The Windows vista/7 skin in development looks nice, but I've yet to see any others. I believe that because to make a skin for CF, you have to buy the program to do it(of course you have to buy CF as well...). But, then again, I haven't really looked as of late. I guess that's my next task.
  6. #446
    May 2008
    I don't have to reformat!! Turns out my capacitor's ground wire popped loose(probably when I hit that pothole going 55 down Main...) but I got that fixed, and everything leveled back out. I updated CF to 2.1.1331 with the new BT stack and everything is working... Except Bluesoleil is running in trial mode, and I can't get it to quit! Any suggestions?
  7. #447
    Apr 2007
    Atlanta, GA, USA
    . . . I updated CF to 2.1.1331 with the new BT stack and everything is working... Except Bluesoleil is running in trial mode, and I can't get it to quit! Any suggestions?
    Jan Bennett has a guide in the CF FAQ on how to register your Bluetooth. It worked fine for me. Here's what it says:
    How to Activate your Bluetooth License in Centrafuse 2.0
    To activate your Bluetooth license in Centrafuse 2.0 follow these easy steps (note 2.0 RC4+ must be installed):
    1. Already be a paid customer of Centrafuse
    2. Already have Centrafuse 2.0 installed
    3. Already have the Centrafuse Bluetooth installed (Custom BlueSoleil Bluetooth stack). When you installed Centrafuse, you should have installed this when prompted.
    4. Log into your My Account page at: https://www.fluxmedia.net/login.aspx
    5. Next to your Centrafuse 2.0 Serial key, you should see a link to get your Bluetooth Serial key. Just click this link and a key will be automatically generated for you.
    6. Copy this key to the Bluetooth License Key field in your Phone settings (Advanced settings must be enabled). Use this serial number to Activate one (1) PC to a single Bluetooth adapter. This will work for THAT Bluetooth adapter only.
    7. If you have an active internet connection in your car, it will try to activate the Bluetooth automatically.
    8. If you don't have an active internet connection, it will prompt you to save an Internet shortcut to a USB drive. You will then put this USB drive in your home/work computer (or anything that has Internet) and double click the URL file. This is explained in Centrafuse before you copy it. This is the exact message Centrafuse gives…
      If possible, Bluetooth will activate over the Internet.
      If no Internet connection is available, you will be prompted for a location to save an Internet shortcut, we recommend saving this to a USB drive. This Internet shortcut can be used on any PC with an Internet connection to generate an unlock code for this PC.
    9. Once you double click the internet shortcut it goes to the FluxMedia web page, which also contains additional instructions.
    10. The Flux website will direct you to the IVT website, where you will take the presented activation code, and save it to a file. Save the file as text.
    11. Now that you have your new Unlock Activation file saved from the Internet enabled PC to your USB drive, plug that drive into your CarPC.
    12. In Centrafuse now, when you click the Bluetooth Enter Unlock Code you get a file browser telling you to select the Unlock File.
    13. Select this file then it will automatically open the file, enter the unlock code, and activate BlueSoleil.
    14. You're all done!
  8. #448
    May 2008
    OK... That didn't work.
  9. #449
    Jul 2007
    Miami
    What is it saying? Does it say the key is already in use? You may need to have FLUX reset it?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  10. #450
    May 2008
    Just says key is invalid
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
