PIX of the AUX battery install:
In-line fuse holder with a 30A thermal circuit breaker:
Battery where the factory air filter housing was:
Reused one of the mounting holes for the ground:
My cold air intake:
Factory air filter housing:
Since I added a cold air intake awhile back, I've been meaning to remove the factory air filter housing. Today gave me a reason to do just that. I removed the air filter housing, and what'dya know? Just enough room for the motorcycle battery(or the two scooter batteries, even). Two trips to AutoZone later, I had everything wired up and ready to test. Preliminary testing went well, but afterwards, my OPUS started acting up. All the wires were attached the same way they were during testing, but the light was blinking twice. I shorted the pins manually, and everything powered up, but I still haven't managed to get the OPUS to power everything on on it's own. Any suggestions? (And yes, I've flipped the plug on the pins on the MoBo...)
Project λ^2 (Lambda Squared or Lambda II)
[??????????] Install ???%
Defecation hit the oscillation
I have no clue what's going on anymore!!!
Coming soon: freeflashstuff.net
If I have time, I'll update it. College is a pain in my arse.
My cold air intake:
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
With the car running, both batteries are at 14VDC. With the car off, the main battery is at around 13VDC and the AUX is at 12.7VDC. The OPUS light blinks twice either way; car running or not.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
I lost all the jumpers... They're all zeroed out, so shutdown delay=10 seconds and shutdown voltage=8.5VDC.
I got my fan box finished today. The ABS cement held what it needed to, so I finished the smaller parts with plastic welding. Pix follow:
Inside:
Finishing the cold air intake is my next step. I still wish I knew what my OPUS's problem is... It still blinks twice...
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
Well, I'm going to Dallas tomorrow morning, so I'll try to do that today. I need to find something to cannibalize plastic from so I can make that divider. I used all of what I cut off of this for the plastic welding and the center piece. A CD case would work, wouldn't it?
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
