Page 52 of 86 FirstFirst ... 2424344454647484950515253545556575859606162 ... LastLast
Results 511 to 520 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #511
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    How much?
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
  2. #512
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    How much?
    Just pay for shipping.... $4.95 for the flat rate box.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #513
    May 2008
    I got the problem with the OPUS fixed. The hot glue thing didn't work, so I took a power switch header extension cable I had laying around and used it to extend the OPUS' cable from the OPUS to the MB, and hot glued it that way. That solved the problem. I still haven't got the Turtle washed and cleaned out yet. If the skies are clear after church, then I'm gonna go wash/clean/vacuum it.
  4. #514
    May 2008
    I got my UniBus adapter in today, along with my converter boxes from FreeDTVShop.com. With the coupon, they were free, even with shipping. One went to my dad, the other two are mine to play with. *evil grin* I have already taken one of them apart and extended the IR receiver. Now I just need a way to power it. It needs clean, regulated 12VDC up to 1 Amp, but I don't want to power it from my OPUS.
    I also started having battery problems today. I went to the local coffee shop to have coffee and study with a friend, I was there two hours, and when I got ready to leave, the battery was dead. I noticed I hadn't shut my door completely and decided my dome light had run the battery down. Then I realized my dome light(and added floor lights, for that matter) are LEDs. They don't consume enough juice to run a car battery down in two hours. I got a jump start from my dad(gave him his converter box) and made it home. I FUBAR'd my Windoze install the other day(OPUS shut off in the middle of hibernate; missing file errors and the like. Repaired last night). I went out to test it, and the battery was fine until I tried to start the car; then, dead battery. I figure the AUX battery is draining the main battery since it can't hold a charge anymore. I pulled the fuse(s) to the AUX battery setup, I hope that solves the problem. If that is the problem, then I will get a new battery or look for a better way.
  5. #515
    Jul 2007
    Miami
    Also, I am sending out the GLI today...... I was running behind with work and did not make it to the post office.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  6. #516
    Newbie ozzy71's Avatar
    Feb 2008
    Atlanta
    I have some questions about your battery failure... My first impression it that this is a coincidence... and you really have had a primary battery failure. Also, since you drove the car to lunch—it would have had the alternator charging the batteries the whole drive. Since you were able to drive the car home, the alternator is working fine… otherwise all the electrical gizmos…. Like fuel pump, ignition, turn signals and A/C would have caused the car to stall out…. God forbid that you had the headlights and radio on!!
    But, since you have changed a few items in the electrical system… lets see what we can find?
    If you have a multi meter, lets check the static battery load, with everything off:
    To do this, set it to DC amps… remove the ground cable, connect the meter between the ground post and the ground. This measures how much load is on the battery. I’d expect around 1.5 – 2 amps max…
    Let me know what you find, and I’ll gladly help you troubleshoot further if you need it!!
    If a little will do a little good, then a lot will do a lot of good.
    2005 Scion XB with AMD X2 64 5600+, 17" Touchscreen, Centrafuse
  7. #517
    May 2008
    I don't have anything on hand right now because I'm not home but I'll check it when I get home. I believe the AUX battery drained the main one because I had power up until I switched the key, then my lights dimmed and I had a dead battery. The AUX battery will not take a charge period. It has dead cells. I disconnected it completely.
  8. #518
    Jul 2007
    Miami
    See thats scary to me....... I think all you have to do is upgrade the alternator, put in a deep cell battery and you should be fine. How often are you honestly going to run the PC without the engine for long periods of time. I plan to use mine in shows and Im not even adding a second battery.
    PS: Could it be your relay system is setup wrong? I mean if the engine is off, the secondary battery does not have access to the first because of the relay.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  9. #519
    May 2008
    Yes, if the ignition is off, the batteries are indeed separate. But when the switch is on ACC, the relay energizes, and the batteries connect. The AUX battery would hit 14.7VDC as would the primary battery when the car was running, but the AUX would fall to around 7VDC after the car was shut off, and the primary to between 13.7 and 12.7VDC. So I believe the AUX was sucking all it could when the relay would energize and it eventually killed my primary battery.
  10. #520
    Feb 2008
    Atlanta
    LOL-- ok... now this makes a lot more sense!!
    If the Aux battery has dead cells, it is a 100% drain on the system while they are connected.
    During your run time, the alternator is providing enough juice to meet the demand, but you have a hole in your system that it just can't fill. Also, since the primary battery has more voltage in it, it's helping bring that AUX battery up too...
    So, the primary battery and alternator spent almost all of their energy trying to fill a battery that was never going to store a charge...
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
