Page 60 of 86 FirstFirst ... 10505152535455565758596061626364656667686970 ... LastLast
Results 591 to 600 of 851
Thread: [DEAD]Project Turtle: 1993 Toyota Tercel/56K=FAIL
  1. #591
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    If it's the intake, it hasn't affected anything until now. It could be water in the gas... Gonna try to go out and get a bottle of HEET to see if it helps any. If it does, I gotta find a new gas station.
    The last oil change was less than 1,000 miles ago, around a month ago. I'm running Pennzoil 10W-30 not synthetic. Is there any particular brand of synthetic you all would recommend?
    I have bad luck with vehicles...
  2. #592
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    Im a huge Royal Purple fan, but thats alittle extreme for you, I tend to floor my car alot (have a major lead foot). Now this time, since I know I am not going to speed much, I used Penziol, they have a sale at Pep Boys, the do-it-yourself sale. For the filter and 5 quarts, it comes to about $35.00. Just remember to ask for synthetic, other wise they will give you regular oil, which come out to about $27.00.
    I have never heard of gas stations pumping out water!!!! Im never ever going to visit your state, lol.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #593
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    This is one of the places where OBD would help, because you'd likely get a read on instantaneous fuel consumption.
    One thought: as we load the alternator more -- by asking it to produce more power for the things we've added -- we use more fuel. It would be most evident in low-speed modes.
    This may be a carburetion/injection issue, though. Is there a performance change? Is it stumbling on acceleration?
    It's also possible the replacement intake somehow opens up more as air volume increases, so it might be interesting to see if you have the same problem when you go back to the original air intake.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #594
    May 2008
    Too bad this thing is OBD-I and not OBD-II, the plug is proprietary to Toyota. I have a pin-out of it, but no time to try to hack anything up. In fact, I should be doing ENGLISH HOMEWORK right now... (that FKN class is going to be the death of me.) I'm installing drivers on the CarPC now. Hopefully I can get to the Turtle and do the re-wire sometime this week since I didn't get to it yesterday.
    Ozzy, is there a circuit that will do like the new cars do and keep the radio on until the doors are opened? Because right now, leaving the radio on, the relay stays open, so both batteries are connected when the key is on. Not to mention,
    [sarcasm]that would add to the coolness factor that is so highly present in my car[/sarcasm]
  5. #595
    May 2008
    Got a circuit, Radio On Until Door Opened
    Just need to find the 1 Amp Diodes involved...
  6. #596
    Newbie merkj's Avatar
    Sep 2009
    Houston, Texas
    I know this is a couple days late, but I wanted to jump in on the synthetic/conventional oil conversations. You can switch between the two as often as you like. Can even mix the two (see the synthetic blends at the store).
    The problem is that synthetic oils are a little thinner than their conventional counterparts. So if you have a small leak and you change to a synthetic, you might want to go with something just a little heavier. Otherwise your small leak may turn into a bigger leak.
    For a recommendation, don't listen to the tv commercials. Any synthetic is better than any conventional oil. HiJack is right, Royal Purple is an awesome oil, but it is expensive and probably not needed for your application. Personally, I use AmzOil. But I have a heavy duty truck with heavy duty needs and I get it fairly cheap. Mobil 1 is a good synthetic oil as well and you can find them in oil change kits or get a 5 quart jug at most Wal-Marts.
  7. #597
    May 2008
    I fixed the link in the post above.... I linked to the wrong circuit....
    Anyway, what kind of 1A diode would I need? I'm thinking Zener, but I'm not for certain... I'm ordering from AllElectronics.com.
  8. #598
    May 2008
    Found my diodes, I need 2 "1N4001/L"s. RatShack carries them in packs of two: here Hopefully the local one has them...
  9. #599
    May 2008
    Quote Originally Posted by merkj View Post
    Your post appeared in the middle of mine! Oh, but it's your first, it had to be approved...
    Welcome to MP3Car, merkj!
    I think I'm going to go to Mobil1 or Q when I change my oil this time, but I think I found out my MPG issue! The intake wasn't getting air... There was a bend in the hose from when I was working on the AUX battery and air couldn't get through it... Why I didn't check it earlier, I do not know.
    CarPC will get reinstalled this weekend if things don't get in the way.
    Also, insomnia and English homework are keeping me up for another long night, and I seem to have exhausted my Mt. Dew supply... Tomorrow=Wal-Mart run for more Mt. Dew and maybe some Red Bull...
    That's all for now!
  10. #600
    May 2008
    I'm almost certain it was that issue with the cold air intake that was causing all my gas mileage issue. I made a trip to Roswell with a friend of mine(about 90-100 miles round trip, depending on how much you drive around town), we went to see "Surrogates" at the theatre there(cause the one here SUCKS!) and I only used 1/8th of a tank round trip. So, (estimating here) about 1.5 gallons and around 100 miles = 50 mpg! I think I'm back in the high MPG playing field...
    Planning on reinstalling the CarPC in about an hour and a half....
  1. Replies: 44
    Last Post: 06-02-2009, 01:28 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. 1993 GMC Sport Truck Project
    By chapstick in forum Worklogs
    Last Post: 06-22-2005, 05:37 PM
  4. Replies: 7
    Last Post: 05-21-2005, 05:43 AM
  5. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
