Page 12 of 34 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 335
Thread: Help Bugbyte kill his car PC with an iTouch/iPhone install
  1. #111
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Crinos View Post
    with SBS-settings you have a dimmer app where you can adjust settings.
    Surly there are others as well, but SBS-settings is a must have for all Jailbroken iPhones
    Thanks for pointing this app out to me. It looks useful.
    The issue I have is not with the iPhone screen - the autodim feature works pretty well. It is with the external video display screen I am using (Xenarc 8"). That does not auto-dim.
    The original screen comes with a single button dimmer that selects low-medium-high brightness. However, to fabricate it into my car I had to discard the bezel and fab a new one. I moved the buttons and the only access to them is via tiny pinholes I drilled to allow them to be pushed with a paperclip. This works fine with a computer because you can auto dim the display via software. With the iPhone, you can't.
    Want to:
  2. #112
    Jan 2009
    Blog Entries
    1
    I played around with appflow, It looks good on my screen but anytime you open an app and then return to the spring board it will resort to the normal springboard and appflow has to be restarted.
  3. #113
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by meagain View Post
    May I jump in with a quick question?
    Bugbyte - do you think it prudent to hold off on all this till 3-4 months from now when the accessory floodgates open, new firmware, probably new iPods/iPhones, boatloads of bluetooth items, perhaps new cords, etc? I'm leaning that way. I'm also fully buying into the rumor of a multi-touch tablet and and the possibilities with that (and it talking to the iPhone/iPod) with full touch control all over the place.
    I just got myself all excited.
    Probably. They're almost certain to introduce something new on the iPhone. I guess I've been hearing the tablet rumor for years but one could theoretically scale the iPhone UP to netbook size I think. Still, I don't see Apple playing in the low cost netbook space. I've been wrong before, but if they did, it would have to be something unusual and almost certainly would add up to an expensive netbook but an inexpensive Apple laptop.
    As for bluetooth, almost certainly there will be a number of new devices out there to make things much, much easier to put this in the car. I was listening to my iPod as I got into the car today and was thinking, wouldn't it be cool if when I turn the car on, it would stream the song to the audio system. Don't see why you can't do that.
    As for me, I'm going to order that touchscreen bluetooth device and see how it works.
    I'm starting to get a handle on the types of problems that have to be solved to make the iPod a great replacement for the car PC. I just need to give it some more thought -especially on the software side.
    Want to:
  4. #114
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by tdub24 View Post
    Nice find! I'm going to check it out. Thanks!
    Want to:
  5. #115
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Okay, I ordered a the bluetooth touchscreen controller. Hopefully, I'll find a way to get it to work with the new bluetooth features in iPhone SDK 3.0. Meantime, I'll test it out on my Mac with bluetooth built in and see how it works.
    There's not much info on it on the site - if you know anything about this controller or how it works, let me know. I'm sure I'll need a hand.
    Want to:
  6. #116
    Mar 2006
    I would rumage through the msi wind forums. That is where I found it. I actually have a wind that iwas thinking or doin this to. I think there are a few posts about it. Looks sweet tho. I wonder if it'll be controlable with the new 3.0
  7. #117
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The ultimate would be if you can somehow calibrate and map locations touched on the bluetooth screen and have the iPhone respond to that as if you were touching the iPhone screen. However, that just sounds a little unlikely. It would be too perfect.
    I'm thinking that I may have to write some kind of app that runs on the iPhone for the car - an iPhone front end, that can receives and respond to the cursor location from the big touchscreen.
    Anyhow, we'll see. It wasn't a terribly expensive device so it isn't a giant loss if it won't work.
    Want to:
  8. #118
    Mar 2006
    let me know
  9. #119
    Feb 2009
    BugByte - I didn't realize you knew programming as well. Have you considered grabbing the 3.0 SDK to play around with? Or maybe you're not at that point yet.
    I found this site interesting. Bluetoothy all over the place. Doing interesting mods, etc.http://www.ubiqkom.org/blog/ Type in iPhone in the search box. Not sure if you've seen this site but you might find a few things worth your reading time?
  10. #120
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Oooh! He's got an external apple bluetooth keyboard working with an iPod touch, running a bluetooth stack from researchers at ETH Zurich and a BT module he's built himself for the Touch.
    That is proof of concept that it is possible to have the iPod talk to other devices over BT.
    I'll be reading some more. He doesn't provide a lot of detail about how he's doing this stuff.
    Want to:
  1. Replies: 13
    Last Post: 06-22-2009, 09:23 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. Replies: 1
    Last Post: 11-27-2004, 06:16 PM
