Page 25 of 34 FirstFirst ... 1516171819202122232425262728293031323334 LastLast
Results 241 to 250 of 335
Thread: Help Bugbyte kill his car PC with an iTouch/iPhone install
  1. #241
    Apr 2005
    yeah I saw that you said the update broke it, that sucks. I am sure that this will be addressed at some point. The cable I am thinking of would connect to the ends of the apple cable and then terminate in a VGA connector. Once your cable works again do you think you might try it?
    I am also very curious to see how your shivaplug computer turns out. I bet with a little work you could make a whole car pc setup with one as long as you didn't expect playback of high quality video.
  2. #242
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by nubz69 View Post
    I'm working to get FTDI running on it right now. If I can do that, then OBD and GPS will be accessible. It's possible, just haven't got it to work yet.
    Want to:
  3. #243
    Mar 2006
    If I had a VGA car screen i'd try it but I don't. Cause the cable is like 5$ shipped on eBay. And the apple cable could be purchased at bestbuy and taken back if "it's not something u needed". They have a 30 day return policy.
  4. #244
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by tdub24 View Post
    So...it has a scan converter built into the cable for $5? 'Cause that's what you need to transform analog NTSC into VGA.
    Want to:
  5. #245
    May 2009
    @bug-i know what you mean about gps apps that pull their map data from "cloud". i took a road trip from chicago to la and purchased the at&t navigator app for a month. while i never lost gps signal, in the areas where i didn't get a cell signal, i only saw a blue dot on my iphone's screen. as soon as i got back into a coverage area, the map tiles reappeared on the screen.
    if i were to use my iphone as full time gps, i would want all that map data locally installed.
  6. #246
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yep, I've tried the navigator app as well and while it works okay, it would be nice if it would download the map tiles you need for the trip you programmed. I don't care if it destroys them when you program another trip. Just so it downloads the tiles when you have a signal!
    If you turn off or get too far off track, I'm okay with having to download new tiles.
    Frankly, I think these apps could be a lot smarter. If your route is a long one planned mostly down highways, why doesn't it load the tiles for, say, the next 100 miles along with tiles around all of the exits?
    If your route is shorter and mostly on local roads, download all the tiles for the trip -or if you're AT&T, you must have an idea of how good your coverage is in the areas you are planning to drive in. Can't you just download the tiles for the areas with weak or congested coverage *before* you drive into them?
    This is the power of the cloud! All this processing can take place on servers where it is cheap and easy to make these types of decisions.
    Want to:
  7. #247
    Aug 2008
    This might be it!
    http://www.xsellize.com/showthread.php?t=54896
    follow the link, read the thread, and see what you think... You guys no so much more about this than I do, bit I've been following because I want to do this too.
  8. #248
    Feb 2009
    I'm just dieing to see some video of these iPhone installs and how they're working. It's near impossible for me to use my imagination with this.
  9. #249
    Jan 2009
    Blog Entries
    1
    I found this. Although the iphone isn't listed it kind of give me some ideas.
    http://www.celiocorp.com/smartphone
  10. #250
    Feb 2009
    I think this is going to be the way to go. I've known this for a year now. I just hope it'll do everything that needs to be done. While it would be nice to mount it in the dash, I'm fine with some type of external mount but up to the existing stereo - just plug it in to the aux and USB if so equipped.
    I pray it's not subsidized in anyway or we are allowed to buy it with no 3g for surely we'll be able to tether it to the iPhone to get 3g on it. I think no one can doubt the existance of Apple's 'tablet' anymore. It's a done deal for me and a game-changer.
    http://gizmodo.com/5335942/an-inside...e-apple-tablet
  1. Replies: 13
    Last Post: 06-22-2009, 08:23 AM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
  3. Replies: 1
    Last Post: 11-27-2004, 05:16 PM
