Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: 2000 Saturn SL2
    Low Bitrate skeet2331's Avatar
    Feb 2005
    Indiana
    2000 Saturn SL2
    I've been a member for this site for a couple years now and finally decided to take the plug and install a carputer.
    1.8 GHZ Intel BOXD945GCLF Intel Atom processor 230 Intel 945GC
    1GB Ram
    160 GB 2.5 Hard Drive
    M2-ATX PS
    Lilliput EBY-701 touchscreen
    Custom Plexiglass Computer Case
    Need to buy
    Ext. DVD
    Centrafuse
    Iguidance
    Here is my car. A 2000 Saturn SL2.
    Here is the stock dash. Double din, great for a touchscreen.
    Feb 2005
    Indiana
    Here is the computer.
    Computer on workbench getting software and testing done.
    Top of Computer Case with PS and cut up mouse pad to cushion hard drive.
    My dash in shambles.
    Feb 2005
    Indiana
    4 awg running down the door trim to the trunk.
    I will post a full wire diagram tomorrow.
    Metra kit. It ended up being too small by about 1/2 in, so I just mounted the LCD to the back of the radio dash panel.
    Test fitting the LCD. It fit much better without the Metra kit.
    Feb 2005
    Indiana
    Plastic Ploxy used to mount the LCD
    Feb 2005
    Indiana
    Here is my wiring diagram.
    I will take some photos today of the screen installed in the dash.
    Sep 2003
    Souf Cakalack
    What did you use to cut the plexi? There are no grounding issues correct?
    Feb 2005
    Indiana
    I used a regular jigsaw with a wood blade to cut the plexiglass. Just be careful of the heat melting the plexi. Also leave the film over it until you are done cutting to help eliminate cracking. I have no grounding issues. It is always a good idea to ground everything to one point. Also run your audio/video cables away from your power cables to eliminate any hum.
    Sep 2003
    Souf Cakalack
    and to drill the holes you used a regular drill bit?
    Feb 2005
    Indiana
    Yeah, nothing fancy needed.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by projekakkord View Post
    i was wondering the same thing. Usually most people screw a cable to one of the MoBo screws so that it can be grounded. I myself built my CarPC into a metal frame of the seats, which is then bolted to the main part of the car.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Please HElp with Saturn SL2 2000
    By phbar1 in forum Car Audio
    Last Post: 06-26-2006, 10:10 PM
  3. Updated shots of the puter - 02 Saturn SL2
    By Yuriy in forum Show off your project
    Last Post: 05-28-2005, 02:17 PM
  4. Introduction: Saturn SL2 owner. Simple MP3 audio
    By DigitalChicken in forum Newbie
    Last Post: 07-20-2004, 12:32 PM
  5. connecting a powersupply to saturn SL2
    By BlinderBomber in forum Newbie
    Last Post: 03-22-2004, 09:19 AM
Tags for this Thread
