Front USB Ports with HDD LED
Here are the pics from the latest completed task. I still need to do some minor cleanup (scratches and spacing) but the main work has been completed. These pics are of the USB ports that I mounted on the front lower console. I also mounted the HDD LED above the USB bracket.
I had to use a combination of tools and improvising to modify the panel. Of course I used a drill for the screw holes, but I also used it to partially make a hole for the USB ports. I drilled a total of 3 holes. I then intentially burned some of the plastic with a soldering iron to form a fairly decent rectangle. After that I cleaned it up with a file and the sander from my Dremel.
For the HDD LED I melted the plastic again with the soldering iron, then cleaned it up with the drill and sander from my Dremel.
Click the picture or link to be directed to the photo gallery.
http://lh3.ggpht.com/_yMY8OPBjw6c/Su...ntUSBPorts.jpg
CarPC Project: Front USB Ports
Preparing the Intake Filter and Grill
If you followed my worklog you would have read that I decided to ditch the top intake fans and will just install a simple grill with a filter. These are the pics of me preparing this next mod to my console.
I decided to use the 120mm filter/grill and cut it in half to fit the top part of the console. This will just help minimize dust from being pulled inside the console.
Click the pics for zoom
120mm Filter/Grill before modifying:
http://www.mp3car.com/vbulletin/imag...7428c4a1f6.jpg
The grill/filter consists of three pieces. The front grill, the filter, and the rear grill.
http://www.mp3car.com/vbulletin/imag...742ca2aac6.jpg
This is the area on the console that the grill and filter will be mounted.
http://www.mp3car.com/vbulletin/imag...743281ac92.jpg
http://www.mp3car.com/vbulletin/imag...743469f6c4.jpg
Inside view of the console where the filter and grill will be.
http://www.mp3car.com/vbulletin/imag...7440e6cbce.jpg
http://www.mp3car.com/vbulletin/imag...7443399d4e.jpg
This is the grill modified.
http://www.mp3car.com/vbulletin/imag...744d62c62a.jpg
This is about where it will be mounted.
http://www.mp3car.com/vbulletin/imag...74506e578c.jpg
That's as far as I got so far today. I will continue later this evening with cutting the console, drilling and attaching the filter.
Intake Filter and Grill- Part 2
I completed the front intake grill and filter. I used the 120mm fan filter/grill I had. I cut it in half and cut holes in the console so air can flow. I could not simply cut a large rectangle and attach the grill because I need to use the console to support the filter to avoid it from falling inside in the console over time due to the air flow.
Click on the pics for zoom.
This is a reminder where the grill is going.
http://www.mp3car.com/vbulletin/imag...7aec4a8068.jpg
I made the first cut.
http://www.mp3car.com/vbulletin/imag...7af02d5b54.jpg
Preparing for the next cut.
http://www.mp3car.com/vbulletin/imag...7afd358931.jpg
Made the second cut. They're not one hundred percent perfect but they will be covered by the grill and filter, plus this will serve its purpose for intake airflow.
http://www.mp3car.com/vbulletin/imag...7b0211ede6.jpg
I cleaned up and sanded the frayed plastic around the inside edges.This will also help prevent damage to the filter.
http://www.mp3car.com/vbulletin/imag...7b0c1de8cf.jpg
A preview of the grill in it's place.
http://www.mp3car.com/vbulletin/imag...7b1465e791.jpg
The completed installation of the grill and filter.
http://www.mp3car.com/vbulletin/imag...7b1a82ea9e.jpg
This is the rear inside view of the filter and grill.
http://www.mp3car.com/vbulletin/imag...7b294796df.jpg
Now that's done..on to the rear exhaust fan.
