Page 16 of 23 FirstFirst ... 67891011121314151617181920212223 LastLast
Results 151 to 160 of 229
Thread: '05 Nissan Altima- Intel D945GCLF2D Mini-ITX in Center Console (Storage Bin Mod)
  1. #151
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Next Part of the Plan
    The next phase of my project will be mounting the DVD drive. I am thinking of mounting it in the front storage bin (see pic below). Next week I will look into purchasing the M4-ATX enclosure which will help mount it against the other wall across from the PC.
    This is the pic of where I'm thinking of mounting the DVD drive. I am hoping to be able to still close the door and only open it when I need to use the drive. Obviously my project was modified after this picture was made. The USB ports are there but the power switch is now located on upper console area.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #152
    Dec 2007
    AZ
    I received my USB Slim DVD drive and USB extension cable. I will post pics later with how I might be mounting this.
    Recent Proj
    Old Proj II
    Old Proj I
  3. #153
    Dec 2007
    AZ
    SlimDVD Drive
    Here are the pics of the SlimDVD Drive.
    Next to a Music CD to display the scale.
    Sitting inside the storage bin to display scale. It can't be mounted as displayed because there is not enough clearance for the drive door to open. It will hit the ledge on the bottom of the storage bin.
    The idea is to be able to close the storage bin door. I will not be using this drive on a daily basis (mainly for software installation).
    I will probably use a combination of the styrofoam (which I would paint black) that came with the packaging (see pic below) and industrial velcro to mount it in the bin. It does not have to be a dramatic experience to mount this. The space is already confined, minimizing movement. I also want to eventually add a media card reader in the bin which would probably be mounted above of the drive.
    I would have to drill a hole on the back of the bin for the USB cable.
    Recent Proj
    Old Proj II
    Old Proj I
  4. #154
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by hexxamillion View Post
    Here are the pics of the SlimDVD Drive . . . It can't be mounted as displayed because there is not enough clearance for the drive door to open . . . I will probably use a combination of the styrofoam (which I would paint black) that came with the packaging (see pic below) and industrial velcro to mount it in the bin.
    With styrofoam, you have to be careful which adhesive you use. Many of them will eat the styrofoam. You'll want to try your adhesive out on some scrap before you commit. One that does work, as I remember, is contact cement.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  5. #155
    Dec 2007
    AZ
    Quote Originally Posted by rdholtz View Post
    True. I think it should be ok. I'm using the velcro that has the adhesive on the back. Either way shouldn't be dramatic to perform this task in my project.
    Recent Proj
    Old Proj II
    Old Proj I
  6. #156
    Dec 2007
    AZ
    Audio Components
    I decided that before I purchase my monitor next week I am going to start on the next upgrade to my audio system.
    I am replacing the rear deck stock speakers with Alpine 6x9's (SPR-69C)
    For the rear passenger doors, Alpine SPR-17C 6-1/2" 2-Way 300W. Currently no speakers are in the rear passenger doors but have pockets that can be replaced by them.
    Those would be the last speakers I need to complete my system. I am still researching what amp I am upgrading to.
    So here is a overview of what my audio system will have regarding speakers. CaaRaaaaZyyy!!
    Click pic for zoom
    Recent Proj
    Old Proj II
    Old Proj I
  7. #157
    Constant Bitrate vull's Avatar
    Oct 2007
    damn thats a lot of cutting and venting... will it look ok when everythings put together?
    and why would anyone want an optical drive in their car if there're holes called USB ports?:P
    imo the main reason for installing a pc into a car is to get rid of the dull radios and cd-boxes...
  8. #158
    Dec 2007
    AZ
    Quote Originally Posted by vull View Post
    The DVDROM will most likely not be used on a daily basis. It's for those times that may require software installation or upgrades that are from CDROMs or DVDROMs. It will not be used for music or movies because all my media are mp3's or avi's. It will make those moments more convenient.
    I will be also getting rid of my head unit so that is not an issue either. I want full desktop functionality out of my PC not just for music, movies or navigation. Everyone has their own unique dream for their CarPC project.
    Recent Proj
    Old Proj II
    Old Proj I
  9. #159
    Oct 2009
    Awesome work man!
    I am planning on doing something similar to my 2003 avalanche. Except I am going to build my own center console because my center console I have currently is not doing so well. Anyways, keep up the good work man!
  10. #160
    Dec 2007
    AZ
    Quote Originally Posted by loganbyers07 View Post
    Thanks! I still have a few more things to do but I'm getting close to completion.
    Recent Proj
    Old Proj II
    Old Proj I
  1. Subaru Impreza 2.5RS '05 Wagon Install... on a budget
    By Pseudo Nim in forum Show off your project
    Last Post: 06-24-2008, 03:38 PM
  2. 2004 Nissan Maxima Install
    By BobbyCreekwater in forum Show off your project
    Last Post: 05-14-2008, 08:22 AM
  3. Freak show - 22 year old Nissan install
    By Yuriy in forum Show off your project
    Last Post: 09-18-2007, 01:09 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. '98 VW Passat 1.8t, budget install
    By Beehphy in forum Show off your project
    Last Post: 06-11-2007, 05:26 PM
