Page 2 of 23 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 229
Thread: '05 Nissan Altima- Intel D945GCLF2D Mini-ITX in Center Console (Storage Bin Mod)
  1. #11
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    I am researching how to hardwire my eeepc power to the car battery. I have yet to find any posts with picture examples or detailed how to's. I have read many posts briefly stating that this is probably the preferred method over that bad word... "inverter".
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #12
    Dec 2007
    AZ
    Time to Go GREEN!
    Ok I have started a post under the forum location for powering laptops/netbooks. Here is the link: Solar Charge your Laptop/Netbook.
    My plans are to implement solar energy in my car for charging my eeepc (to start with...who knows where else this may lead to )
    In short..here is my brainstorm schema. Please follow more details at the link I posted above located in the 'Powering your Laptop' forum section.
    Click image for a larger zoom
    *********** EDIT *************
    Soooo... here is my revised idea. See more details at the forum post for powering your laptop.
  3. #13
    Jul 2009
    '05 Nissan Altima- EEEPC 2G Surf CarPC Using LCD Rearview Mirror as Monitor Reply to
    Ever considered the EeePC T91 tablet? You could fold the screen down and operate it via the touchscreen.
  4. #14
    Dec 2007
    AZ
    That model actually seems real cool. Although it is LED backlit, I wonder how it looks in sunlight. Either way seems like a good upgrade from my 2G surf.
  5. #15
    Low Bitrate Xygar's Avatar
    Jul 2009
    Provo, Ut
    How does your "mirror" work as a mirror? I know you have the reverse camera, but I'm still curious if the rearview mirror can still function as such when you're not using it for video.
    Overall, I really like the install. The idea of using your Wii remote in car is pretty sweet.
  6. #16
    Dec 2007
    AZ
    Quote Originally Posted by Xygar View Post
    The mirror is polarized an works great as a rear view mirror. At night I don't have the drama with those people that like their high beams. Regarding using it as a monitor..this solution is only temporary and serves its purpose. I will say that during the day it is not as bright, but that can be adjusted on the mirror, in addition, it is connected to a pc-to-tv converter box and I tweak the brightness more with converter box.
  7. #17
    Dec 2007
    AZ
    Time for a Change?
    I am considering swapping out my EEEPC for a Fit PC 2. The first generation of this small form factor PC had some cons and possibly limitations as a CarPC. This newer generation has stepped up its cpu and remains lower power along with more features. Check it out and tell me what you think.
    http://fit-pc2.com/wiki/index.php?title=Main_Page
  8. #18
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    I think the Fit2 sounds great at first, but it's an expensive solution with some downsides. Its main advantage is that it's pre-packaged.
    The Atom Z530 used in the Fit2 has 512KB L2 cache, where the Atom 330, used in the D945GCLF2 mainboard, has 1GB of L2 cache. The Fit2 uses soldered-in memory, meaning you're limited to 1MB. Buying an open system means you can use more memory.
    You can easily go to a faster video processor by changing to the new boards available from Logic Supply. I particularly like the look of the Zotac IONITX-A-U, which uses the Atom 330 with Nvidia 9400 graphics and onboard power supply.
    Click image to enlarge.
    At $189, it's a faster, much-less-expensive solution that allows up to 4GB of memory.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  9. #19
    Dec 2007
    AZ
    Quote Originally Posted by rdholtz View Post
    Thanks for the suggestion which actually agrees with another alternative mod I am thinking of doing in my car.
  10. #20
    Apr 2007
    Atlanta, GA, USA
    Glad to help. There's an interesting and lengthy review of the Zotac board at Anandtech. Here's the comment that got my attention: "The general application performance of the Zotac Ion isn’t actually any better than the Intel D945GCLF2. It’s when you look at GPU-enabled applications that the Ion holds any real performance benefit. Blu-ray playback or 3D gaming are its real performance strengths; if you plan on doing neither then the platform isn’t very useful." That persuaded me to stick with the Intel D945GCLF2 board I have, which cost only $80.
  1. Subaru Impreza 2.5RS '05 Wagon Install... on a budget
    By Pseudo Nim in forum Show off your project
    Last Post: 06-24-2008, 03:38 PM
  2. 2004 Nissan Maxima Install
    By BobbyCreekwater in forum Show off your project
    Last Post: 05-14-2008, 08:22 AM
  3. Freak show - 22 year old Nissan install
    By Yuriy in forum Show off your project
    Last Post: 09-18-2007, 01:09 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. '98 VW Passat 1.8t, budget install
    By Beehphy in forum Show off your project
    Last Post: 06-11-2007, 05:26 PM
