Page 4 of 23 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 229
Thread: '05 Nissan Altima- Intel D945GCLF2D Mini-ITX in Center Console (Storage Bin Mod)
  1. #31
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Ditching the After Market Head Unit?
    Ok so...I think I am finally breaking down and deciding on replacing my head unit with my PC. I can run cable from the sound card to my AMP. When it comes time for me to upgrade my AMP I would prefer to get one that has a remote to adjust and tune it. Any suggestions?
    I am going to test this with my EEEPC which I have mounted as my CarPC currently. I will need to get a higher grade Jack to RCA cable adaptor but we shall see how it sounds. If all goes well as could be expected then that will cut more cost from my project (I was going to upgrade my head unit). This will also provide an easy switch over to use my Windows Mobile phone as a backup media player. Since the LCD Monitors have 2 video inputs, one will be the PC and the other will be my Phone if needed (though no interaction unless I use the VNC...we shall see). I use my rearview mirror as my backup camera already so that is covered.
    I found this straight forward overview of connecting my PC to my AMP: CarPC Hacks
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #32
    Dec 2007
    AZ
    USB Sound Card Solution
    I know there are many USB sound card solutions out there but I think I found one that adds an "easy to reach" option for controlling the sound. If I decided on this, the upgraded audio jack to RCA cable will be connected from this straight to my AMP.
    Creative Labs Xmod USB Sound Card
    These are the specs:
    Connectivity USB Mini-B
    Line Out - 3.5mm (1/8") Stereo jack
    Line In / Mic in - 3.5mm (1/8") Stereo jack
    Headphone Out - 3.5mm (1/8") Stereo jack
    X-Fi Technology
    X-Fi Crystalizer
    X-Fi CMSS-3D Virtual
    X-Fi CMSS-3D Headphone
    Earphone Specifications Frequency Range: 140 Hz ~ 20 KHz
    Sensitivity: 112 dB ± 3 dB (I/P Level:1 mW)
    Impedance: 32 ohm ± 15%
    Plug: 3.5 mm (1/8") stereo miniplug
    Power Requirements (USB or AC Adapter)
    Supply Voltage : 5V +/- 5%
    Current : 1A
    Power : 1W
  3. #33
    Dec 2007
    AZ
    Which Power Supply? CarNetix CNX-P2140 or M2-ATX-HV Intelligent PSU
    Ok...after some more forum reading and manual reading I wonder if I should get the CarNetix CNX-P2140 rather than the M2-ATX-HV Intelligent PSU.
    They both generally have the same goal in preventing improper shutdown and protecting from battery drain. I am, however, especially interested in the "Pulse Start Feature" of the Carnetix. I have been looking for such a solution for a while now.Search for term pulse in the Manual.
    Any suggestions? How well will the CarNetix work with the Intel D945GCLF2D Mini-ITX?
  4. #34
    Dec 2007
    AZ
    Quote Originally Posted by hexxamillion View Post
    OK...So my question was already answered in this post. Even though I am no longer using a Zotac IONITX, I believe this answer still applies being that the Intel board I am going to use is similar.
    Carnetix it is! Time to update my checklist in post#22.
  5. #35
    Dec 2007
    AZ
    My Center Console Modify Plan
    I think I am going to purchase a center console from a junk yard or online (I saw some people are selling online). This will avoid me having to chop up my stock and will serve as a backup in case things don't work out quite how I want them to.
    This is basically what I will be disassembling and modifying. These pics are to provide a general idea of what I will be working with. My interior is tan not black. These pics are from a post on ebay...just to use as an example.
    I plan on modifying the storage bin as the area to mount the motherboard and other components. This is an actual pic of my console...look at that wasted space.
  6. #36
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    The Zotac and Intel boards aren't similar in power supply. The Zotac board uses an external 19V power brick, so it needs 19V from your power supply; the Intel board uses a 24-pin ATX connector, so it can use either PSU to get the 12V, 5V and 3.3V it needs.
    The Carnetix isn't going to solve any power issues. On the upside, it would still be an excellent choice, and you'll gain pulse start. On the downside, you'll spend twice as much on your PSU.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  7. #37
    Dec 2007
    AZ
    Quote Originally Posted by rdholtz View Post
    Yeah. I realize the power supply differences but I think the Intel with the CarNetix may better suit my needs...or wants rather. Thanks for the feedback.
  8. #38
    Sep 2009
    I would double check on that x-mod. If I remember correctly the jog dial isn't for adjusting volume but for adjusting the crystalizer.
  9. #39
    Dec 2007
    AZ
    Quote Originally Posted by LancerAM View Post
    Good looking out. I will have to find a retailer that might have one on display.
  10. #40
    Dec 2007
    AZ
    I came across this thread about a USB CarPC Amplifier. This is very interesting...wondering if anyone has had experience with this? Here is the online store link.
    This is definately something I have been looking for. Too bad after you do the euro to $$ conversion you're looking at around $330 or so including shipping and tax. Neat idea and maybe waaaaaay down the road I may consider it just to satisfy my own curiosity or just to be unique..realizing probably not too many will have such a device.
  1. Subaru Impreza 2.5RS '05 Wagon Install... on a budget
    By Pseudo Nim in forum Show off your project
    Last Post: 06-24-2008, 03:38 PM
  2. 2004 Nissan Maxima Install
    By BobbyCreekwater in forum Show off your project
    Last Post: 05-14-2008, 08:22 AM
  3. Freak show - 22 year old Nissan install
    By Yuriy in forum Show off your project
    Last Post: 09-18-2007, 01:09 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. '98 VW Passat 1.8t, budget install
    By Beehphy in forum Show off your project
    Last Post: 06-11-2007, 05:26 PM
