Page 5 of 23 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 229
Thread: '05 Nissan Altima- Intel D945GCLF2D Mini-ITX in Center Console (Storage Bin Mod)
  1. #41
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Windows 7, Centrafuse & Windows Mobile (xv6900/HTC Vogue)
    Today I tested Centrafuse (trial version) on my Virtual Machine running Windows 7. Bluetooth connectivity took some figuring out but now I know what I need to do it's all good. Obviously I am limited with the trial version (on a virtual machine) but for general functionality Centrafuse ran flawlessly on Windows 7. My Verizon xv6900 was paired flawlessly and even the A2DP functionality worked without issues on CentraFuse. I played a video on my phone and the audio played through my speakers. I was able to make a call through Centrafuse and setting up my phone was easy.
    I was able to setup my Gmail IMAP easily through Centrafuse and it worked great.I was able to send an SMS through my IMAP to my phone. Mighty nifty that it also has quick replies to select and you can add.
    So mainly because Centrafuse so far appears to be less hassel (if at all) I will probably be purchasing it rather than using Ride Runner. Don't get me wrong Ride Runner appears to be a great product and has come a long way but I like the functionality of Centrafuse better...just personal preference..they both are great front ends in any case.
    ....it's a shame that Bluesoleil is not free... too bad it doesn't come bundled as a full version with Centrafuse..it's only a trial but at least it's affordable. That would be one of the things I prefer LINUX over Windows..at least simple software components such as Bluetooth Managers are free. I never had any issues with Bluetooth on LINUX...does the same stuff but it's open source.
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #42
    Dec 2007
    AZ
    Quote Originally Posted by hexxamillion View Post
    Shows how much of a newbie I am with Centrafuse. Apparently Centrafuse does come with Bluesoleil bundled but it's a modified stack for Centrafuse. So I'm sure I will get complete functionality once I purchase Centrafuse...no more Bluesoleil disconnects due to 2MB data transfer limit on the trial.
  3. #43
    Dec 2007
    AZ
    Updated Component Checklist
    I updated my post with the new components I now have from my checklist. Post#22
    Check it out!
    I forgot to mention that I received my new front dash cover from Coverking. I am eventually going to be modifying that with flexible solar panels...down the road..after the PC build is complete. View my thread Solar Charge your Laptop. The title was created from my first and current CarPC project using my EeePC. I will be modifying that but it could still be applied to other applications aside from a laptop.
  4. #44
    Dec 2007
    AZ
    Time to Test Components
    I purchased a USB port (x 2) to Motherboard header extenders w/bracket. I am going to bench test some of the components (power switch, memory, SSD, Windows 7, blah blah) that I have so far and if all is well I will at least install Windows on the 32GD SSD.
    We shall see how things go.
  5. #45
    Dec 2007
    AZ
    Test Progress
    So I hooked up the following: (pics coming soon...what a crazy bench setup)
    NOTE: I'm not as cool as the majority of you that have your own garage or shop...I'm working with what I got, out of an apartment.
    • Intel D945GCLF2D Mini ITX motherboard
    • PSU
    • Ethernet cable
    • 2GB DDR2 Memory module
    • 32GB SSD (via SATA connection)
    • Power Switch
    • Dual USB to Motherboard header cable
    • PS/2 Mouse & Keyboard
    • LCD VGA Monitor
    • Audio out
    • DVD-RW/ROM (via SATA connection)
    The system booted so fast I missed the F2 prompt for me to access the BIOS. Once I got to the BIOS I set it up to boot from USB because I created a Windows 7 RC bootable USB. It successfully booted using the Windows 7 USB and I was able to proceed with the install.
    So that's as far as I got for now. I will start working with installing motherboard drivers and all the other driver installation drama that's involved with any new system.
  6. #46
    Dec 2007
    AZ
    Test Progress
    While installing the motherboard drivers it failed with the Realtek LAN Driver and Media Graphics but not sure about that because I can still access the internet with no problems..strange. I never had driver installation failure before while setting up a new system but it appears that things are still fine. The Device Manager didn't indicate any hardware problems.
    I am going to say that my Windows 7 RC and Motherboard drivers installation were successful.
  7. #47
    Dec 2007
    AZ
    Done for Now
    Well I am done for now. I will continue tomorrow with setting up other software. I created this post on my new Intel Mini ITX system.
  8. #48
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Congratulations!
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  9. #49
    Dec 2007
    AZ
    • PSU
    • Ethernet cable
    • Power Switch
    • LCD VGA Monitor
    • Audio out
    So these are the pics of my crazy mess of a testing bench. I have the mobo sitting on motherboard standoffs.
  10. #50
    Dec 2007
    AZ
    Quote Originally Posted by rdholtz View Post
    Congratulations!
    Thanks! Still have some work to do but it's always fun to hook things up to see how they run.
  1. Subaru Impreza 2.5RS '05 Wagon Install... on a budget
    By Pseudo Nim in forum Show off your project
    Last Post: 06-24-2008, 03:38 PM
  2. 2004 Nissan Maxima Install
    By BobbyCreekwater in forum Show off your project
    Last Post: 05-14-2008, 08:22 AM
  3. Freak show - 22 year old Nissan install
    By Yuriy in forum Show off your project
    Last Post: 09-18-2007, 01:09 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. '98 VW Passat 1.8t, budget install
    By Beehphy in forum Show off your project
    Last Post: 06-11-2007, 05:26 PM
