One thing I had wanted to do in my old Tercel was replace the Visors with visors that had an lcd in them. I had even purchased them but got lazy and never installed them. So I figured I would to it on the burban.
Well as you can see just doing a straight swap would make it look pretty funny. Since the interior is a tan and the visors I have are black that just wont look quite right. The other thing is you can almost put to of the small visors in the place of the oem visor.
What is my solution well I will move the guts over.
This is the OEM visor with the cover off and the mirror and lights removed.
And the guts to the LCD replacement visor.
I will have to desolder those five wire at the top of this board to pull the wire out of the support tube and then slip into the OEM tube. And then resolder it.
I will have to cut the button section off the LCD visor and figure a way to mount it to the OEM visor but it is doable.
Sorry that is as far as I got last night before my girlfriend yelled at me to go to bed.
------------Next Day---------------------------------
Had to run home on my lunch break to let the dog out and decided to do a little more work on the visors.
Desoldered the wires from the LCD visors board and snaked the wires out of the hollow support bar and then coaxed them back into the OEM visors hollow support bar.
Resoldered the wires to the board.
Desoldered a couple of just support wires that was holding the button board to the other board and pulled it away from the other board leaving its double sided tape.
Did some rough cutting of the space for the LCD just using some snips. Will need to go back with the dremel to finalize the opening space and take away the little bit I still need to in order to fit the LCD. At this point I realized I should of waited on doing the resoldering of the wires, at least I will know for the other one I have to do.
Just a dry fitting of the LCD to the visor frame, looking for where I still need to remove plastic to make it fit.
Thats all I got done on my lunch break. I am trying to maintain the extender part of the visor. I think I will also have to make a new cloth cover for it all but it should be fun.
LinkBack URL
About LinkBacks
, cant wait for some more updates
