Results 1 to 10 of 16
Thread: 4runner carputer project
    Mar 2009
    Hello guys,
    I'm a long time reader here and finally pulled the trigger and starting my carputer project for my 4runner; Initially I was specing out all the components for my rig, but It turn out to be a bit over my budget. I was going to buy a used 7" EEE PC, to power the system, but i didn't want to tear down a perfectly working netbook.
    After some searching, I have decided to pick up one of these:
    It's a plug and play barebone system, plug in my drive, load the os, wire it up and go.
    Let the fun begin.... I'll post more progress soon....
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread moved to worklogs.
    Want to:
    Mar 2009
    I just missed that entire sub forum; I think I was reading w/ one eye.
    thank you BUG!
    Mar 2009
    here's a quick run down of the specs on this little box;
    Case Extruded Anodized Aluminum measuring: 10" x 9.25" x 3.125"/254mm x 235mm x 80mm more info
    Processor: ATOM 330 1.6GHz Dual Core 8 Watt CPU with 1Mb L2 cache 533MHz FSB
    Graphics: Intel GMA 950
    Audio: Realtek ALC662 High Definition audio codec + Composite/RCA Line Outputs
    USB: 6x USB 2.0
    LAN: 1x 10/100/1000 Mbps
    Rear Panel I/O
    2x Ps2 for mouse and keyboard
    1x VGA
    1x 7 pin S-Video
    1x 10/100/1000 LAN
    1x RS 232 COM
    1x Parallel Port
    6x USB 2.0 ports
    3x Audio: Line in, Line out, and Mic in
    Monitoring and Management Power Management (Supports S3 standby)
    Fan Speed Control
    Wake on USB
    Wake on PCI
    Wake on LAN
    Wake on Keyboard
    Wake on Mouse
    Memory (Supports up to 2Gb) 1024Mb/1Gb PC5300/667MHz more info
    M2-ATX Smart Power Supply: Connects directly to the battery,
    Voltage regulation,
    Automatic Start-up more info
    Built-in Bluetooth-Exclusive Feature Internal V1.1/1.2 Vista Compatible,
    50m/150' Range
    one year manufacturer's warranty
    Mar 2009
    The screen I'm using is the DELONG 7", it's not good as the Lilliput one, but it should be enough for me (for now)
    Mar 2009
    i'm using this DeLong ebay 7" LED powered backlid, supposedly using Sharp LCD, it's cheaper than the Lilliput, and the constrast is lower, but I think it'll be sufficient for me, for now.
    Mar 2009
    some of my carputer parts came in this week. here's a peak at the board and the power supply attached. the OS will be loaded on a 16Gb USB flash drive. I will have a 120Gb external usb drive for media storage. It allows me to easily unplug it and take it inside the house to plug it onto my pc to quickly load songs, movies, etc.
    Mar 2009
    so far the project is coming along.
    i have added a turtle beach 5.1 usb sound card, it sounds alot better than the integrated one.
    a pic of a bench test run.
    Feb 2007
    So...have you had anything plugged into the ALC662 on board sound card yet? I've got this same rig in my car right now and I'm having a HELL of a time getting that thing to put out.
    Nice progress btw! I love the 4Runner...good truck to throw one of these in.
    Mar 2009
    Quote Originally Posted by cbevis View Post
    in my book the ALC662 is decent, but it's software is POS. I could not for the life of me kill the Realtek installed software, it's keep cutting out due to its auto-detection of headphone port. Hence the reason I went with the Turtle Beach 5.1 USB sound card---it has 3 sets of independent outputs (front, rear, center+sub). it's sounds excellent on my bench test. The out puts are going straight to the amps.
    my setup is generic, consists of two amps, one 4-channels, one mono-block to power a sub.
    everything is installed in the car now, I 'm just waiting for a harness for the car, and I should be finished this week.
    if you're having trouble with signal, i suggest adding a crossover to take the inputs from computer, then the output of the crossover to the amp(s).
    like one of these
  1. Speedy (Mazdaspeed6 Carputer Project)
    By golfguy in forum Show off your project
    Last Post: 06-21-2010, 10:23 PM
  2. Need help carputer project
    By alphaae in forum General Hardware Discussion
    Last Post: 02-10-2009, 01:48 PM
  3. Replies: 10
    Last Post: 09-09-2008, 02:46 PM
  4. Replies: 5
    Last Post: 07-10-2008, 09:16 PM
  5. Carputer project for bimmer 06 550.
    By FXer35 in forum Newbie
    Last Post: 05-06-2008, 07:34 PM
