Results 11 to 20 of 22
Thread: The Swift Shuttle
  1. #11
    Nov 2008
    OBD (On Board Diagnostics)
    1. I bought an OBD interface kit: I bought this one for just less than 40 delivered: http://cgi.ebay.co.uk/ws/eBayISAPI.d...3AIT&viewitem=
    (PLEASE NOTE: I can tell you the one I bought works, I couldn't tell you about any other, I just took my chances)
    2. This is what you get for your dosh:
    3. This is where the port is on the Suzuki Swift - note I have removed the interior trim piece directly below the steering wheel in this photo. The port goes straight up.
    4. This is just one print screen i managed to grab and save before the laptop battery died on me:
    I'll add a little more later
  2. #12
    Nov 2007
    for the 1st time i am hearing that OBDII scanners working on suzukis. this is kool...
    will this work on suzuki swift VDI also?
  3. #13
    Nov 2008
    Quote Originally Posted by MichaelPlace View Post
    Sorry - I barely understand most of the OBD terminology! I just know that the ELM-327 protocol is supposed to be able to read most new cars.
    I was surprised because the googling I'd done had just found loads and loads of people who were saying they just couldn't get it to work on their Suzuki.
  4. #14
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    All that matters is that your scanner can access the protocol that your car uses. All car companies sometimes come up with their own, its the programmers for the OBD2 to come up with a way to read it. If im not mistaken though, Suzuki works with GM. I have to assume they are using parts from GM, and one of GM's protocols are being used now. Anyways nice install.....
    Few questions though.... have you thought about putting a double din screen, like a EBY701? You have the space to do it, and I think it would look more OEM. You can easily relocate the Audio Head Unit some place else. You have like the ultimate dash, so easy to work with and screams double din. I have a DODGE, before they used double din, so I had to have someone heavily mod my dash to get a screen in there. I used to have a flip out, but it didnt seem OEM.
    Old Dash and New Dash:
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #15
    Nov 2008
    Yeah I did consider the single screen in the double din - but for quite a few reasons I didn't go for it:
    + A bit flashy for the area I park, the motorized is hidden.
    + No back-up plan if it doesn't work - I drive ten hours a week to and from work, if i'd have chosen the single screen I'd have had no tunes since christmas while everything was being sorted.
    + I can't adjust the screen for glare - so I'd need to spend a lot more money on the anti-glare screens.
    It's something I'll look into when I fancy a change over
  6. #16
    Newbie jarjar4's Avatar
    Dec 2003
    Hi Michael,
    Just to share with you, I'm using a Elmscan ISO USB (equivalent to a Elmscan 323), and was able to pull codes from my ECU on my Suzuki Swift (non-JDM). However, it didn't work on my other friend's SwiftSports though...
    Cheers.
  7. #17
    Nov 2007
    how comw it works with some of the swift and for some, it dosnt?
  8. #18
    Nov 2008
    depends - depends which ODB diagnostic tool you buy.
    Depends where you are and what swift you've got. Mine is a European swift so it's ECU follows local protocols it seems. But a Jap or USA might have a different ECU and adhere to a different OBD protocol.
  9. #19
    Nov 2008
    Screen Tests
    just a couple of old shots I found when testing the screen.
  10. #20
    Nov 2008
    Screen in-car-test
    AND a youtube video of the wire mess I was in earlier!
    [media]http://www.youtube.com/watch?v=HQ-zqPR3-IQ&feature=channel_page[/media]
  1. Hiinfo N53 in Suzuki Swift?
    By fitzy75 in forum General Hardware Discussion
    Last Post: 04-13-2009, 02:58 PM
  2. The new: Shuttle XPC Barebone SD39P2
    By RoTalk in forum General Hardware Discussion
    Last Post: 03-03-2007, 07:32 AM
  3. Powering shuttle ST20G5. OPUS or INVERTER??
    By ironic in forum Power Supplies
    Last Post: 08-19-2006, 08:01 AM
  4. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 04:13 PM
  5. Smallest Touch PAd Mouse... or Shuttle Mouse QUESTION!!!
    By Boozshey in forum General Hardware Discussion
    Last Post: 01-23-2005, 02:38 AM
