Results 1 to 10 of 14
Thread: The new CarPC setup
    Nov 2008
    The new CarPC setup
    So I in the process of building a new car pc for the honda It will be similar to my last build, but a few better parts.
    The specs of this build:
    Motheboard : Zotac 9300 1333 FSB Geforce 9300 onboard video, up to 8 GB DDR2 800 ram 12 USB ports. onbaord WIFI, and SATA
    CPU: Intel Core 2 Duo 3.16 GHZ
    RAM: 4 GB DDR2 800
    Soon to come a Western Digital 1TB HDD, a new power supply and some other stuff.
    On to the pics
    All the stuff so far
    Mobo out of the box
    RAM installed
    CPU install
    Put the whole thing on the case bottom its going in which is a gutted cd changer to keep the stock look in the trunk
    working on attaching a fan to the northbridge/graphics chip as it gets really hot without one, might have enough room for two as i dont want it to burn up
    CD changer top on still need to install the hard drive and power supply once i get them but this is what it will look like
    One intake fan near the processor and an exhaust fan on the other side
    YAY it turns on
    should give you an idea how its built
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i think that when you say "a few better parts" it might be an understatement. how much did that setup cost you?
    Nov 2008
    those parts just pictured were around 390 i believe. I figure i wont have to upgrade for a long long time haha
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Love the Zotac board! How tall does that chipset heatsink sit? It looks like with the fan it's same height as the stock Intel heatsink/fan! And is that a "low profile" heatsink/fan on the CPU or is that the regular height one?
    Nov 2008
    i can measure it but the CPU fan is the stock intel cooler and heatsink it looks like it should do a pretty good job so i didnt upgrade it, i can measure it if you want
    Jan 2009
    Iowa
    I was just curious, when I bought the processor for my project it was what Intel calls a "Low Profile", which compared to the one that came with the processor I bought just a little over 6 months ago, it is low profile.
    Just seems like a massive heatsink on the chipset, but I guess with those beefy graphics
    Sep 2008
    an e8500? jesus..
    Nov 2008
    Quote Originally Posted by JoeyFiasco View Post
    an e8500? jesus..
    indeed i am brave
    Nov 2008
    just out of sheer boredom i figured i would post up some new pics of the build.
    Got a new heatsink and fan and it should cool much better then the stock one did haha
    figured it will get quite hot in the car so figured it needed upgraded. rather not burn up the processor and seeing as how this is the fastest build i have seen done in a car pc application might as well do it right :P
    got a different case for it instead of teh cd changer idea i went with a micro atx case which i will be hiding up front, its a little smaller then a shoebox i was just worried abut temps in the trunk and it will e less wires i have in the car with it up front. Still need to put in the hard drive and such but its a start
    i am making it removable also so if i want to take it inside and game with it (yes it runs games well i play GTA IV and crysis on it lol)
    its an all black case i just have the top cover removed
    Dec 2008
    how are you able to play gta4 with onboard graphics?
  1. Replies: 9
    Last Post: 01-13-2008, 08:41 AM
  2. Proper way to setup my CarPC using RR
    By black_mamba in forum Road Runner
    Last Post: 11-17-2007, 07:02 PM
  3. brand new carpc setup with multiple problems.
    By casurfer911 in forum General Hardware Discussion
    Last Post: 01-08-2007, 10:06 PM
  4. Manual Power-On CarPC setup Diagram!
    By ironic in forum General Hardware Discussion
    Last Post: 01-12-2006, 05:54 PM
  5. temporary carpc, will this power setup work?
    By bobthebaker in forum Power Supplies
    Last Post: 10-11-2004, 04:21 PM
