Page 16 of 16 FirstFirst ... 678910111213141516
Results 151 to 158 of 158
Thread: 1986 Fiero GT 6cyl [Work Log]
  1. #151
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Quote Originally Posted by JohnWPB View Post
    a plugin for OBDI will definitely be following shortly
    Cool, looking forward.
    WinALDL.......... this is the software that you get bundled with the cable. Looks good. And it's free, got to luv that!
  2. #152
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thumbs up Update on the Dash Project......
    Ok, Malcom2073 contaced me on Yahoo, and he thinks he has most of the code done already, as he has an 87' Camaro with OBDI. WooHoo! This would be fantastic. I will post when I know more.
    On another note, not much of an update, other than what is to be done, not what has been done
    Well, after working on this custom center console, I got to thinking, the dash is still going to look very stock in comparison.
    I figure if I am covering the original instrument cluster with the fiberglass dash cover, and doing some fabrication, I may as well swap out the instrument cluster entirely So I started looking around, and I just purchased a digital dash out of a Cavalier Z-24. The Z-24 dash is still a bit dated, compared to modern cars, but is an easy swap, and I think will look better than the stock cluster at least It is a pretty easy swap, as it uses all the same sensors as the Fiero, and is a wire-to-wire swap for the most part.
    My plan is to remove the bezels and such from the digital dash, and put a smoked Plexiglas cover over the whole thing. I will have some additional "Dummy lights" along the top of the dash showing when the CarPC has power, fog lights are on, and a couple other indicators. I also have a back up sensor system that I will put behind the glass as well, thats what you see above the gauges in the photo below. It shows the distance to objects behind the car when backing up.
    This is a quick Photoshop concept on how I am picturing it looking.
    I am also putting a blue gel (The plastic sheets they put on stage lights to change colors of lighting colors on a stage) over the gauges, to make the dash more blue instead of the existing teal.
    I still have a lot of fabrication work to do, but It is all starting to come together as to how it will all be done now.
    My Fiero Build Thread
  3. #153
    May 2007
    Thumbs up
    Looks clean with digital instead of analog gauges. Yes, much better.
    Malcom, great to hear the coding is going well .......87 Camaro, gotta' luv the 3rd Gens F-Bodies.
  4. #154
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    My ECU does both 160 and 8192 baud, so I can help with the low speed generic plugin that JohnWPB wants. In all honesty, as he said to me that Mitch said to him, it's not all that complicated. I'm putting together some stuff for John to try out, not entirely sure if 160 baud is possible for VB6, but if not then I can easily put together a DLL that he can use for the actual serial access.
    I really like that digital-looking dash. I always loved that look in the Cavaliers and older Camaros.
    RevFE
    My Shop
  5. #155
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Sounds great! I have been trying and trying to figure out a way to read this OBD1 data into RR for months now
    I used to have an 86' Cavalier Z24 about 6 years ago. It's gonna be a flash back having that same dash again.....
  6. #156
    Newbie CanuckMark's Avatar
    Feb 2009
    Orillia, Ontario, Canada
    This is good news - I've been working on this as well for my Fiero and VB6 based front end so staying tuned.
  7. #157
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    Very Nice!
  8. #158
    Nov 2008
    SoCal
    even after all this time away from this forum, this is still the first thread I checked and it definitely did not disappoint.
    the gauges painted blue was an amazing touch and I was looking forward to seeing those installed but it looks like the new dash cover and display are now in the works in it's place.
    can't wait to see how this all turns out.
  1. Replies: 9
    Last Post: 05-20-2009, 11:52 AM
