Page 2 of 16 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 158
Thread: 1986 Fiero GT 6cyl [Work Log]
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Good suggestion, I will just have to toy with it and see how it looks, as I would like to have the screen lower.... as mentioned just a case of not too low to be blocked by the shifter.
    Quote Originally Posted by HiJackZX1 View Post
    I saw that big shifter.... I wasnt sure if the camera was close to it, or if it was really that big. I also started to think about the AC controls, I know new cars use electronics, but older cars (especially AMERICAN) used that weird air tubing system to change contols and stuff. Also that pull line stuff. So relocating those will be almost impossible.
    Actually I got lucky on this one The controls are all electronic. The only thing that is not, is the cable to move the vent door from hot to cold. Surprisingly, they can also be seperated very easily from what I read. Here was another project where someone was re-designing the center console:
    My Fiero Build Thread
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by JohnWPB View Post
    Oh WOW, I bet Nexson could do something like that for you!
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #13
    May 2009
    Thumbs up Followed you from PFF.
    Good luck on your build.
    I want to also replace my center console with something that looks better. The stock center console liked to separate from the plastic skeleton and would need re-glued and will never hold up to the Florida heat.
    I like the back part of the dash but the gage pod and the center console are dated bad. I don't really want something out of a new car but would like to use the Fiero dash as a building block.
    It will be interesting to see how your build progresses.
  4. #14
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Welcome to the MP3Car forums! I have a good idea of how I am going to do the center console. It will be something based on the idea of the above wooden one. Separating the A/C controls give some extra space, as well as reducing the radio to a single DIN from the present 1.5 DIN. I just am going to rearrange things in it, as well as probably add some newer / more modern looking A/C vents.
    EDIT:
    Something like this for instance:
  5. #15
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    EDIT:
    are you going to upgrade the other vents as well? because 2 round vents and 2 squared vents might look a little off
  6. #16
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yes, all of them would be the round ones. I have all this planning going on now, trying to measure, sketch up what it could look like, and really have not started to do actually anything as of yet heheh. It's all in the early planning stages, and any part of it could change at any time.
  7. #17
    Jul 2007
    Miami
    EDIT:
    Why not cut out the middle man and just get rid of the head unit? Only thing you would have to do is buy a 4 channel amp and discreetly put it in the trunk or under a seat. Doing that will give you more dash space to work with.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #18
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I like having a head unit as a backup audio source in case of puter problems. But mostly, I like it for the real volume knob. Yea yea, I know, the shuttle and such, I just like the simplicity of the head unit volume.
    I also have a parrot blue tooth kit that interfaces with the radio for hands free calling ect.
    I just cut out some cardboard to the size of the console area in the car. I took tons of measurements, and it looks like everything is going to fit just fine. The Vents, A/C, controls, 10" screen and the head unit.
    It will all work, BUT I really wanted the A/C vents on the side. There is just no room what-so-ever to do it. The instrument cluster butts up right against the center console. Otherwise I would have come up with something similar to this:
    There is just NO way to do it with the room that I have to work, thus the plan "B" of having the A/C vents on the top.
  9. #19
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just did a wiki look at this car.
    I assume this is how the whole looks on yours
    Did Pontiac just give the responsibility of designing and building of the dash to a group of preschoolers armed with only cereal boxes and washing up liquid bottles and then some stickybacked plastic to stick it to the shelf that is the back of the console?
  10. #20
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    Just did a wiki look at this car. I assume this is how the whole looks on yours.
    No, actually they were first graders, and they were also allowed to use milk jugs as well. These first graders were only allowed to use a straight edge ruler, and not get fancy with any curves and contours
    But....Yes, that is the stock dash on 99% of Fiero's, with a few differences in the tach and speedo based on the engine ect.
    If all goes well, it will look nothing like that when I am finished with it
    In perspective, the Center console & upper center console are quite easy to modify. Re-Designing the dash gauge cluster is much harder to do. I will start with the center "floor console" and the center radio console first, and go from there.
  1. Replies: 9
    Last Post: 05-20-2009, 11:52 AM
