Results 11 to 20 of 26
Thread: 2007 Mitsubishi Triton (Aussie)
  1. #11
    May 2009
    holmesie, indash monitor is that posible to use for triton?
    put at the HU location, will it stuck when screen open?
  2. #12
    Nov 2006
    Rubidoux, CA
    Most car's I've owned over the years have had a dash cover... And I'm not from oz... I always had them to cut down on the reflected heat of the summer sun. Makes a HUGE difference. It actually surprises me that it surprises you...
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
  3. #13
    May 2006
    Calgary, Alberta
    Quote Originally Posted by holmesie View Post
    I guess having carpet on the dash is a bit daggy, but it also cuts down the reflection of the dash on the inside of the windscreen
    Windscreen? Okay, now I'm just being mean!
    Quote Originally Posted by CraziFuzzy View Post
    Summer? Sun? Sorry, I live in Canada, I'm not familiar with those terms. Just kidding, guess it's not an issue here.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #14
    Newbie holmesie's Avatar
    Apr 2009
    In the sticks - CANOWINDRA NSW Australia
    Quote Originally Posted by Maheriano View Post
    haha that would be windSHIELD for you?
  5. #15
    Apr 2009
    Quote Originally Posted by junhe View Post
    i think this would not work in the Triton - it could hit the gearshift lever when opening, and would come in contact with the panel above the HU location where the air and vent control are
  6. #16
    May 2009
    ur RV meter u take it away or install at other place?
  7. #17
    Apr 2009
    hi junhe, the meter has gone - I did not need it because I have a Scanguage - it calculates my fuel consumption etc
  8. #18
    Apr 2009
    hi holmesie;
    i have triton too, and planing car pc. how do you open the plastic part for the touchscreen?
    and is your screen readible when it is sunny? i guess it is not transflective, but the position of the screen is somewhat away from direct sunlight(with coverings) so do you advice a transflective or standart touchscreen?
    thanks
  9. #19
    Apr 2009
    G'day sinisa,
    The plastic surround comes off by pulling as it is held in by plastic clips - pull it towards the rear of the car (do not pull upwards!)
    My screen is not transreflective, but it is LED backlit - I have not had a problem yet with direct sunlight. AT the time I could not afford a transreflective screen, but I don't regret that at all!
    hope that helps
  10. #20
    May 2009
    OBD II can find out how many liter diesel left in the tank?
    or only scangauge can do that?
    thinking to buy the OBD II, but still looking, dunno which one is more suitable
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
