Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MKIV GTI First Carpc install
  1. #11
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    I know compusa has some really nice high-flow, ultra quite 40mm fans. I had used some on a setup almost 2 years ago and they are still working like new. Make sure you get some nice fans otherwise the bearing will come apart in no time, and its a real pain to switch out fans that are glued so defiitely use screws to hold them on in case they need replacing. I definitely like the way that all your stuff tucks away into that cubby.
    Oh and I was going to give you a little suggestion to put you ahead of the game. If you haven't already purchased a slot load DVD player for your dash consider getting a slot load Blu-ray player. I know there are a couple makes out there (Panasonic is supposed to have a nice one). It might put a little dent in your wallet but at least you don't have to worry about it getting obsolete any time soon.
  2. #12
    Newbie HumungousBacon's Avatar
    Apr 2009
    Cocoa, Fl
    began working on a custom ipod dock today will get some pics here in a min
  3. #13
    Newbie frankrizzo's Avatar
    Jun 2006
    CT
    doesn't look too bad. what is it a mkiv vr golf? i noticed teh climatronic. Follow the aforementioned advice. put a decent sized fan on the bottom pulling air in. put a grill and i suggest using some of that green plastic scratchpad stuff as a debris filtre. you'll get decent cooling. nice choice of location but not so hot on teh execution. the factory cd changer bin is a perfect size if you can make yourself a little case to stuff in there, if you vent that smaller case you won't have to vent the whole cubby. MOUNT YOUR HDD...ASAP! vibration kills drives.
  4. #14
    Apr 2009
    Cocoa, Fl
    Thanks. Yeah its a 24V VR6. Love it. Thanks for the great advice will look into that.
  5. #15
    Jun 2008
    Should I assume you have an ipod classic since your using an ipod dock cause I have tried everything for my touch but there is no way to get it into disk mode.
  1. Replies: 1
    Last Post: 07-31-2008, 06:37 PM
  2. CarPC install in my Mk2 Mr2 Turbo.
    By 1RyanRs in forum Show off your project
    Last Post: 07-11-2007, 12:11 PM
  3. Need some expert advise on how to install CarPC
    By virengoyal in forum Newbie
    Last Post: 11-28-2006, 06:59 AM
  4. 1985 corrolla GTi rear boot install
    By konman in forum Show off your project
    Last Post: 09-11-2006, 06:16 PM
  5. 1993Opel Vectra carpc install
    By [mp3]neo in forum Worklogs
    Last Post: 11-12-2005, 09:22 AM
