Results 1 to 10 of 15
Thread: MKIV GTI First Carpc install
    Newbie HumungousBacon's Avatar
    Apr 2009
    Cocoa, Fl
    Ok so here are some pics of what i've completed so far. Dash pieces are all still apart cause i know that as soon as i put them all back on ill end up wanting to do something else and have to remove them all again.
    Hole under the screen i plan on molding a slot load dvd player so that only the slot is visable.
    Just another view
    Carpc installed in compartment hidden in hatch back.
    compartment closed. Carpc completely hidden from sight of weary thieves
    Ok so this grey plastic piece just above that compartment I'm thinking of putting two or three small 40mm fans with small ducts that go down to the case to pull out hot air while cool air can enter through the grill at the bottom of the compartment.
    when the hatch is closed the plastic will still be able to breathe since the cover doesnt cover over the plastic it just rest next to it
    Back seat area i plan on building a floor from the front of seat area all the way back with either 2 10's or 2 12's with the amp recessed in the middle of the two subs. There is a step up of about 4inches where the seatbelt recievers are. So there is plenty of room for the subs to sit
    Sugestions and comments greatly appreciated
    Apr 2009
    Cocoa, Fl
    Moved to worklogs since not a completed project
    Apr 2009
    Cocoa, Fl
    guess no opinions
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by HumungousBacon View Post
    guess no opinions
    Two things to consider: (1) your worklog wasn't in this forum at first, so people here didn't see it for a while, and (2) it's a national holiday weekend, and there are lots of activities that pull us away from the Web; views and posts are lower for a few days. Don't feel like the Lone Ranger. When someone has something pertinent to say, they will.
    Your installation looks good, so far.
    Fan Placement
    If you put fans side by side, they just circulate some of the same warm air. You might consider putting them at the top and making them both pull air out. Place matching-size holes -- maybe with grilles over them to keep trash out -- as a point to pull air in. Hot air rises, so putting the fans at the top pulls it out in its natural flow pattern.
    You could also put the grilles at the top and the fans at the bottom, pulling air into the plenum, but that works best if the plenum is pretty well sealed, other than the openings you placed. And those bottom fans that pull air in are more likely to get clogged with waste.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Nice looking install. What front end are you planning to run?
    My Fiero Build Thread
    Apr 2009
    Cocoa, Fl
    I haven't decided yet. I like CF so far. I'm trying out RR as soon as I get the new board and stuff in and everything running again.
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Let me know if you need any help with the setup, I am not too much help with hardware but I can definitely give you some pointers with the front end, especially if you plan on using centrafuse. I am in Orlando so not too far away. Looks pretty good tho so far. I would definitely consider putting in vents since your case looks like an aluminum heatsink. I found that with cases like yours that they tend to suck up heat when not running. What ends up happening is the computer fails to start sometimes (during hot days) as it is already well above the working limits.
    Apr 2009
    Cocoa, Fl
    The case is at the top its built from lexan. The black metal thing your talking about in the middle is the factory installed Monsoon amp. The little black box on the left side is a project box that i had to build to be able to use my factory amp.
    Low Bitrate Xygar's Avatar
    Jul 2009
    Provo, Ut
    That cubby in the back is perfect for the car pc, very stealth.
    I'm with rdholtz on fan placement. Exhaust fans on top should pull enough hot air off the system. It should create enough air movement to pull in cooler air from your hatch (it looks like there is already a grill at the bottom of the compartment where air can enter). If it turns out to be too hot, think about maybe placing an intake fan over that grill .
    Overall, looks good. Can't wait to see the dash fabrication completed.
    Apr 2009
    Cocoa, Fl
    yea im thinking about going with two or three 40mm fans to pull out hot air from the case.
  1. Replies: 1
    Last Post: 07-31-2008, 06:37 PM
  2. CarPC install in my Mk2 Mr2 Turbo.
    By 1RyanRs in forum Show off your project
    Last Post: 07-11-2007, 12:11 PM
  3. Need some expert advise on how to install CarPC
    By virengoyal in forum Newbie
    Last Post: 11-28-2006, 06:59 AM
  4. 1985 corrolla GTi rear boot install
    By konman in forum Show off your project
    Last Post: 09-11-2006, 06:16 PM
  5. 1993Opel Vectra carpc install
    By [mp3]neo in forum Worklogs
    Last Post: 11-12-2005, 09:22 AM
