Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 89
Thread: 2001 Mitsubishi Eclipse Spyder "The Project That Never Ends!"
  1. #51
    Jan 2008
    yeah, many of the holes did etch fine, but about 3-4 of each board didn't etch at all, so i didn't remove the press-n-peel stuff for a fear that i wouldn't be able to find the holes-- so between the red light going through, and the white light above, it was very easy to locate!!
    next time, i am def. going to make the hole template a little larger though-- the ones i made on this template were based off the exact max diameter of the led pins-- next time, i will actually attempt to give my self a little more leeway.. and while i was populating the boards, i was starting to realize that i focused too much on keeping the leds in the same direction, where if i had just reversed a couple of strings, i could have combined about half of the spots that i had to create jumpers for...
  2. #52
    Jan 2008
    tiny update(still lengthy post though!!)
    all the tail lamp boards are completed, i just need to finish painting the housings, and then add in the voltage regulators.
    but in the mean time, i got bored with the tedious-ness of all the soldering for the tail lamps, and finished, and started a couple other projects:
    first, was the led dome lights:
    one of the boards after etching:
    populated board:
    these use 4 Cree-brand plcc6 led's wired 2-per series with a 39 ohm resistor.
    9v regulator wired up getting glued to heatsink(yes, i am missing the capacitors--decided i didn't need them for these):
    gluing the boards into place, and showing off my rare " pc board holding tool" (only available at harbor freight!!)
    the completed assembly right before i reinstalled the mirror:
    and the 'rough' output pics. it was daytime, and my car is right next to the garage window, so some of both pics is slightly brighter:
    original setup:
    new setup:
    and the other update-- i finally took care of my subs. the box i have been using has 2 chambers with about 0.25-0.30 cf each.. i had modeled the box over and over for the last couple years, and had figured out that a single sub really needed both chambers..
    so i drilled some 4-4" holes in the center divider(being careful to sand the edges down to prevent 'chuffing') and hooked up only one of the 4 voice coils so my amp had a 4 ohm load. i left the other sub unconnected, so it is now just a passive radiator.
    the subs have definitely changed-- they haven't changed overall output, but the freq range is much better. i am considering connecting a pot to the passive sub to try to tune it a little to get everything to work better, but am otherwise pretty happy with it.
    and the last update:
    i have received all the parts for my led reverse lamp project, and have started figuring out the heatsink capacity:
    in a bad mistake, i thought it would be better to put both on a single piece of aluminum tubing. when they were correctly coupled to the tubing, they had a 5deg/min rise in temp... i really think i could have cooked a egg with it if i left it on longer...
    this shot is just a tad over-exposed, but is overall pretty accurate on the amount of light that these put out:
    with the help of some members over at hidplanet, my design has been revised to use 1 heatsink per led.
    at the moment, i have started to drill some old computer heatsinks i had laying around though, in the process heated them up, and found that they don't get rid of the heat very fast without a cooling fan.
    i do intend to use a cooling fan in the design, but the goal is to run the setup at around 75% capacity without a fan if it were to fail.. the area everything is going is mostly open, so water/dirt entry is possible, and i am expecting the fans to fail eventually...
    that's all for now!
  3. #53
    Jan 2008
    Update!!
    i decided last night to do a hid retro to my stock housings, and have been like a kid the day before christmas since...
    after taking about 6 hours, everythings installed:
    is it just me or is my car starting to look more like a "Cars" character?
    i also got my badly-corroded prop-rod painted:
    now to just finish my other projects...
  4. #54
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Awesome progress! I did some LED upgrades on my last Altima. I will be doing the same on this one eventually.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  5. #55
    Jan 2008
    thanks!
    with my brothers car out of service, my car had to get pulled out of the garage tonight, so i grabbed my camera and got some output shots:
    the only order is how i shot them:
    i also seem to have a small fogging issue:
    the projector units are bone stock, and were never near any of the paint, the really big silicone 'washer' is between the projector and oem housing, i guess the shroud paint could be reacting, or possibly the bulb holder area is touching the oem housing?
    time to do some more research..
  6. #56
    Dec 2007
    AZ
    Yeah. I know those give off some heat. In any case looks great. At least they aren't those weird blue ones. I prefer the crystal colors myself.
    Recent Proj
    Old Proj II
    Old Proj I
  7. #57
    Jun 2011
    Dublin, Ireland
    Dude, you are an inspiration to us all!! Fantastic work and what a car!!
    Keep it up..
  8. #58
    Jan 2008
    thanks!
  9. #59
    Mar 2011
    Marietta, Ohio
    Has your fogging dissipated? Did you bake your shrouds after you painted them? I'm debating on whether or not I should use high heat paint... but they don't make body match paint in high temp around here...
  10. #60
    Jan 2008
    i don't know.. personally, i only have about 1 hour on them, though my brother has been driving the car for the last 2 weeks every other day, so i might need to look at it again..
    i don't believe that the paint is what is smoking-- i believe it might just be oils near the bulb/reflector.. it would start doing it even after 2 min of running the bulbs, while most of the reflector is still cool to the touch..
  1. Project FTPC - 1995 Mitsubishi FTO - U.K.
    By Vacheron in forum Show off your project
    Last Post: 01-16-2011, 03:21 PM
  2. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 06:10 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Mitsubishi Outlander 2003 Project
    By angelito46 in forum Newbie
    Last Post: 05-23-2007, 09:05 AM
  5. Mitsubishi Space Cargo project
    By canopy in forum Show off your project
    Last Post: 02-07-2006, 12:34 AM
