Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 89
Thread: 2001 Mitsubishi Eclipse Spyder "The Project That Never Ends!"
  1. #61
    Jan 2008
    ^a update on that-- the housings are now crystal clear--it proably just was the oils burning off.
    and another couple updates:
    led reverse lights(link only because i need to stop keeping 3 threads on the same topic):
    http://www.hidplanet.com/forums/show...rse-lamp-build
    led tails:
    so a little over a month later, i have finally figured these out enough to continue working on them.
    my biggest problem was tinting the lenses-- i tried niteshading them, but it either came out really splotchy, or was way to dark for even the brightest of led's--my xp-g flashlight on the 40-50 lumen setting was perfectly tolerable shining through the lenses--it should have at least partially blinded me..
    i tried the vinyl approach to tint the lenses, but that ended up in utter fail-- i got one lens to lay down correctly, the other lenses had all sorts of bubbles, and wrinkles. and at $50 a try, it was not worth trying again..
    so last week, i came up with a hair-brained solution using some spare lenses i had-- window tint film.
    after briefly trying out some 20% film(sandwiched between the housing and the lens), i am really happy with the results!!(only the large circle is tinted in this pic):
    with led boards:
    so today, i epoxied everything in place, and hot-glued the back of the pcb's to prevent corrosion..
    and just so everyone doesn't think i am perfect after getting everything all done, i fired up each array only to find that one of the series strings wasn't lighting:
    after blindly yanking off the hot glue that i just put on, i found the problem-- a bad solder joint:
    after resoldering, and testing, all was well:
    so nearly 1-1/2 years in the making, i am finally nearing the point of installing them onto the car...
    assuming i am motivated enough tomorrow, i will build the 2 'driver' assemblies-- 3-12v sharp vregs in a aluminum enclosure that is currently planned to be mounted either behind the tails, or in the trunk..
  2. #62
    Jan 2008
    and finally installed:
  3. #63
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Nice!
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
  4. #64
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Very nice job with the LED's man! Mad props! Got me wanting to do the same with my eclipse....
  5. #65
    Aug 2011
    Awesome work soundman. I could only dream having your skills. Lol even though it took you 1 1/2 yrs to do it. It was really worth the time the fact that it's a one of a kind item.
  6. #66
    Jan 2008
    thanks, though it started as a duplicate of a one-off item
    bwracing00 on club3g.com originally came up the with the skyline tail idea a couple years ago(my first pic of his setup from MOD is dated 9-25-09), i just added my own ideas with the lighting..
    all this stuff really isn't that bad--time consuming, but much of it uses much of the same basic body/fab work that any other plastic project uses(turbocad did a excellent writeup in the fab section on building your own bezel)-- whatever you want to do, i can almost guarantee that there is a tutorial on how to get the desired effect--maybe not to do the exact idea you have, but always to do parts of it..
    i do this stuff for the challenge because i have no idea what i am doing at the start of it, and want to learn. and there is no better way to learn then to build it.
    come on!! someone with a eclipse needs to out-do me, so i have a reason to do it again!! (hint-- it would be only slightly more work to create led tails that use the entire real estate of the housings-- similar to mercedes tails.)
  7. #67
    Jan 2008
    yet another update-- reverse lamps and license plate light are done. so the rear of the car is 97% complete. the last thing i want to play with is a back-lighted mitsubishi logo.
    night shots to come later..
  8. #68
    Jan 2008
    and now some night shots:
  9. #69
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Great job Soundman.
    Dr Obvious says, "What about your third brake light?"
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
  10. #70
    Jan 2008
    that was done, just forgot to post it here(i keep a worklog @ club3g, here, and hidplanet, it is hard to remember which one i updated sometimes):
  1. Project FTPC - 1995 Mitsubishi FTO - U.K.
    By Vacheron in forum Show off your project
    Last Post: 01-16-2011, 03:21 PM
  2. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 06:10 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Mitsubishi Outlander 2003 Project
    By angelito46 in forum Newbie
    Last Post: 05-23-2007, 09:05 AM
  5. Mitsubishi Space Cargo project
    By canopy in forum Show off your project
    Last Post: 02-07-2006, 12:34 AM
