Results 1 to 10 of 14
Thread: 94 Accord Wagon CarPC Worklog *updated April 12*
    Jul 2009
    Smile 94 Accord Wagon CarPC Worklog *updated April 12*
    Car
    1994 Honda Accord Wagon EX
    **UPDATE**
    April 12, 2010
    Carputer installation was finished last year but I unfortunately I had no time to post up pictures and such as the Canadian weather caught up with me.
    That being said, the Acer netbook I was using died on me because of the cold so I have been carputer-less for the whole winter...
    Now that the warmer weather is back, I am revamping the carputer - new brains, new centre console - and even thinking of hacking apart my dash even further... but it is all time dependent...
    I'll still be using the Lilliput 7"in screen, but this time I'll be mounting it in the center console. (I previously had it mounted and built a center console around it, which proved different, but it is not factory looking IMO)
    The new brains of the carputer is a Asus EEEbox 1.6GHz upgraded and overclocked to 1.7GHz with 2GB ram and a 64GB SSD to prevent it from dying on me in extreme weather
    Front end is undecided yet, but I have been playing with XBMC and a MCE remote - however it lacks a built in GPS function (or maybe a lack of integration into the interface - at least to my knowledge, but this is where I'm hoping to implement my iPhone into the picture)
    Sometime this week hopefully Ill post some pics up of the mockup that I am going for.
    Sep 2008
    Western Australia
    Hey, nice to see another Accord on here. I have a 95 sedan, and was thinking of possibly putting in a bigger screen, but I just cannot see how it is possible to put in a screen that large in our centre console/dash ? Are you replacing the whole dash so it can fit? I can't wait to see some pictures.. will be really interesting
    Jul 2009
    Reserved...
    Jul 2009
    So today was the day that I visited Plastic World at Sheppard and Allen Rd in Toronto. I picked up 3 sheets of scrap Plexiglas to use for my carputer build for $7.00 plus $3.99 for the cement.
    I must say the gentleman there was EXTREMELY helpful and knowledgeable... I highly recommend dealing with this place and will do in the future.
    There are a lot of pictures as I am trying to document each step of the fabrication process as well as possible.
    I didn't run into any major problems at this step other than not being able to score and break the Plexiglas in a straight line.
    For the smaller bits located in later pictures I ended up just using a hand saw to cut it.
    I was able to score the Plexiglas and then snap it into the following pieces in order to make a faux box in which to mount my laptop internals into...
    http://img.photobucket.com/albums/v3...S/IMAG0069.jpg
    http://img.photobucket.com/albums/v3...S/IMAG0070.jpg
    This is WELD-ON #16 Clear Solvent Cement, perfect for joining Plexiglas, acrylic etc. It is a thicker consistency rather than just using liquid epoxy.
    It was recommended to use this product by the guys at Plastic World because it is perfect for welding two or more pieces of plastic together that are not perfectly perpendicular to each other (or perfectly square) as in my case with the poor attempt at cutting the Plexiglas.
    http://img.photobucket.com/albums/v3...S/IMAG0071.jpg
    http://img.photobucket.com/albums/v3...S/IMAG0072.jpg
    Below is a close up shot of the cement in action, it flows viscously into the spaces created from a non-perfect cut, melting the plastics together and then forming a solid joint within a minute.
    http://img.photobucket.com/albums/v3...S/IMAG0073.jpg
    http://img.photobucket.com/albums/v3...S/IMAG0074.jpg
    Almost done...
    http://img.photobucket.com/albums/v3...S/IMAG0075.jpg
    AND THE BOX IS DONE!!! I was so excited... I still am just talking about it.
    This was my first attempt at cutting and welding plastic together and it was so easy... I youtube'd some videos on using Weld-On #16 and found some useful tutorials... I'll try and dig up the links and post them here.
    http://img.photobucket.com/albums/v3...S/100_0001.jpg
    So I dropped in the laptop guts and started to mock up the fittings...
    http://img.photobucket.com/albums/v3...S/100_0002.jpg
    There will be ample room in this case for cooling, which i will document in later posts once it is completed
    http://img.photobucket.com/albums/v3...S/100_0004.jpg
    This is the back of the LCD screen from my VAIO laptop, I had to modify the housing to make the wire come out where the board is so that I have enough play to hook it into the motherboard without extending the wires.
    You can see here that I dremeled out a hole before actually measuring anything and had to abandon it in favor of one with easier access
    http://img.photobucket.com/albums/v3...S/100_0013.jpg
    And the proprietary connector...
    http://img.photobucket.com/albums/v3...S/100_0014.jpg
    Just a quick mock up of the case and how the motherboard will be mounted.
    http://img.photobucket.com/albums/v3...S/100_0015.jpg
    Dremeled out a hole for the single USB port that will power my 7 port hub I got off of trusty ole eBay
    http://img.photobucket.com/albums/v3...S/100_0016.jpg
    A closer shot... This Plexiglas stuff is really hard to work with, it can be so brittle yet a dremel will melt it causing it to warm when trying to cut straight... I haven't yet figured out what tool would be best to create holes like this...
    http://img.photobucket.com/albums/v3...S/100_0017.jpg
    Here is the hole that the LCD cable will pass through... I started it with a drill bit then played around with the dremel... not the cleanest, I will fix it up later...
    http://img.photobucket.com/albums/v3...S/100_0018.jpg
    The next two pictures show how the USB will line up with the opening, The motherboard has it on a ribbon cable that I will have to bend up and mount to the Plexiglas in a weird manner... I will be experimenting with different screws in which to mount them with... see below...
    http://img.photobucket.com/albums/v3...S/100_0019.jpg
    http://img.photobucket.com/albums/v3...S/100_0020.jpg
    Here is the monitor connector beside my drawing of where it will actually be...
    http://img.photobucket.com/albums/v3...S/100_0021.jpg
    These are the feet that will be glued to the bottom of my case that the motherboard will sit on and be screwed to... I didn't want any metal to be exposed therefore I glued three 1/8 thick sections of Plexiglas together, I must now find screws small enough to actually hold the motherboard into these "feet"
    http://img.photobucket.com/albums/v3...S/100_0023.jpg
    http://img.photobucket.com/albums/v3...S/100_0024.jpg
    http://img.photobucket.com/albums/v3...S/100_0029.jpg
    The box was made to fit snugly into the factory DIN space allocated for any stereo. I will be bolting it into the metal brackets you see on the left and right side with rubber grommets to dampen any harsh road conditions...
    http://img.photobucket.com/albums/v3...S/100_0030.jpg
    http://img.photobucket.com/albums/v3...S/100_0031.jpg
    http://img.photobucket.com/albums/v3...S/100_0032.jpg
    Here is a back shot of the LCD in place... There is little room between the LCD and the computer case, which is intentional as this setup requires the LCD to be close to the motherboard as I didn't want to extend any LCD ribbon cables...
    http://img.photobucket.com/albums/v3...S/100_0034.jpg
    http://img.photobucket.com/albums/v3...S/100_0035.jpg
    http://img.photobucket.com/albums/v3...S/100_0036.jpg
    So that was my day today...
    tomorrow I will be mounting the "feet" and motherboard to the case, I will be mocking up the top lid of the case and fabricating the cooling system...
    My Dynatron arrived in the mail a few days ago but I cannot start to mold the LCD into the center console until my case is completed...
    Stay tuned for more updates...
    I am also working on a piece to contribute to the WIKI under the plastic fabrication section... I am hoping that I can document some good pictures and write some instructions... We will see how dirty my hands become when attempting this as that will affect how many pictures I can take (don't wanna ruin my borrowed camera... THANKS SIS!)
    Sep 2008
    Western Australia
    Hey, how have you been going with this? Interested to see how it turns up as I'm thinking about moving my screen from down below in the centre console to higher up. It's only a 7" though, so not as big as yours, but still would be better having the screen in a more friendly location.
    Jul 2009
    Well, I had finished molding the lcd into the center console, but when i went to mock up everything and power up the computer, NO POWER... ARGH!!!
    so basically this whole setup is trashed because I have tried to test every connector and ribbon cable and I just give up. Finding another VAIO laptop (VGN-TX51P) might be near to impossible since they were $2500+ in 2004 so if anyone is interested in purchasing this LCD already pre-molded into a 94-97 center console, PM me...
    Anyways, I caved and ordered a lilliput touchscreen from mp3car store... I should have it by sunday and will hopefully have the system up and running by the next sunday (pending cold weather)
    I was so tempted to get the 10 inch model and fab it up but that would leave 2 inches of space below it for my add-ons, which is not enough space...
    Going back to the fabrication... I thought my use of dynatron turned out pretty well, its too bad I have to abandon it... This stuff is so much easier to work with than bondo or fiberglass
    some pics (sorry for crappy blackberry quality)
    http://i38.tinypic.com/2ytv6gx.jpg
    http://i34.tinypic.com/70zuwm.jpg
    http://i36.tinypic.com/2nvartf.jpg
    http://i36.tinypic.com/kbps75.jpg
    http://i35.tinypic.com/1494fgy.jpg
    http://i37.tinypic.com/2coirtu.jpg
    Sep 2008
    Western Australia
    Damn man that sucks about the laptop. Maybe it's a good thing as that screen might not have been as readable as a Lilliput (which is pretty bad in itself) in sunlight? Anyway it sucks with our car how the centre console and heater controls are separated like they are, because otherwise could put the screen in between them so it's higher up.
    Good luck with the install
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by sophistications View Post
    I feel your pain. Same issue with my EEEPC..of course no where the status of you Sont definitely was an inconvenience. Nice work though. You gave me an idea on how fix some spacing I have around my exhaust fan.
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Jul 2009
    So I got my Lilliput touch 629GL screen from mp3car.com store and I realized at once how small it is... I don't think I like it too much, I'm kinda regretting not buying the 10.4 inch one now...
    Anyways, I sat in my garage today playing around with the screen and thinking of ideas of how to mount it. I didn't want to open the case and mold it into my center console so I came up with something ingenious (in my opinion )
    I also wanted to recess the screen a bit and add some sort of cover to attempt to shade the screen from the sun...
    After spending about 20 minutes ripping my beautiful 11.1 inch Sony LCD out of my center console I immediately began to cut and shape some ABS plastic to form the pictures below.
    Since the Sony laptop crapped out on me I had to find a different setup. Luckly my girlfriend was kind enough to donate her ****ty Acer Aspire One 8GB SSD netbook. So far I have been loading software (Ride Runner, VLC, Winamp, etc) on it and it doesn't lag how it did when she used it for word processing, youtube, music, internet, skype, peer-to-peer (you can see why it kept freezing) The netbook will have a home in my glovebox... more pictures to come when I move on to that part of the project...
    ONTO THE PICS
    There are quite a few so you can get an idea of what I did today, and yes this was all done today from 3pm to 9pm... I gave up going to the gym because I was so into it...
    Comments? I'd love to hear em...
    I am working with Ride Runner and it appears to be an interesting program to skin (which I will be embarking upon in the winter months...)
    http://i46.tinypic.com/2d8qn0o.jpg
    http://i45.tinypic.com/4r6w7b.jpg
    http://i50.tinypic.com/u52fb.jpg
    http://i48.tinypic.com/2rpeb5v.jpg
    http://i50.tinypic.com/2ufg949.jpg
    http://i48.tinypic.com/118p209.jpg
    http://i49.tinypic.com/2m47hix.jpg
    http://i50.tinypic.com/15zp9o0.jpg
    http://i46.tinypic.com/qo6rg7.jpg
    http://i49.tinypic.com/fkwrr9.jpg
    http://i47.tinypic.com/10ojuc4.jpg
    http://i45.tinypic.com/1zx6ja.jpg
    http://i46.tinypic.com/263ubz7.jpg
    http://i48.tinypic.com/j6ptgn.jpg
    http://i46.tinypic.com/95y1c2.jpg
    http://i49.tinypic.com/14sia8o.jpg
    http://i48.tinypic.com/2csdtvl.jpg
    http://i49.tinypic.com/2luq8mf.jpg
    http://i50.tinypic.com/vesxls.jpg
    http://i50.tinypic.com/2wnps9j.jpg
    http://i47.tinypic.com/1nzpqf.jpg
    http://i47.tinypic.com/t5t835.jpg
    http://i50.tinypic.com/2mfh2b.jpg
    http://i45.tinypic.com/2dkbrm8.jpg
    http://i45.tinypic.com/24w7xhg.jpg
    http://i46.tinypic.com/5ujx5h.jpg
    http://i50.tinypic.com/2i71s82.jpg
    http://i45.tinypic.com/15gscio.jpg
    http://i45.tinypic.com/8wxg7m.jpg
    http://i49.tinypic.com/1zcpsna.jpg
    http://i45.tinypic.com/15s7xvq.jpg
  1. 2004 Accord navigation with carPC
    By blazer563 in forum Newbie
    Last Post: 02-04-2011, 11:49 AM
  2. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  3. Accord '94 Head Lights
    By i3igmind in forum General MP3Car Discussion
    Last Post: 05-16-2006, 11:10 PM
  4. WTB: Accord 94 LX Air Bags
    By i3igmind in forum Classified Archive
    Last Post: 07-25-2005, 03:12 PM
  5. OBDI and Honda Accord ('94(
    By Envitro99 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-07-2004, 02:12 PM
Tags for this Thread
