Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Holden commodore VZ SV6
  1. #11
    Apr 2007
    Chester,
    Yes, it was a massive move, especially from manual to auto - I guess it has semi-sequential paddles, but it is not the same!
    I was getting desperate to buy a car and get rid of my old one, especially when it had a few issues already and was offered 5k for it by the dealer lol.
    I bought the screen, soon I should have the PC components and start install!
    and yes the dollar is doing pretty well, hence i pushed to get the screen. Especially when it was expensive.
    and you never know, we might meet one day
  2. #12
    Sep 2009
    We might have to compare notes some time. I am starting my project on my Pontiac GTO which is basically a Monaro and very similar inside.
  3. #13
    Apr 2007
    sounds good to me.
    I will be updating the thread as I go with full instructions and pictures.
    This site's community helped a lot and it is the least I can do in return.
  4. #14
    Apr 2007
    ok update :
    I finally got this project on the move.
    just purchased the carpc, already have the monitor and other hardware.
    I updated the first thread with the new hardware including the new wiring diagram (which is not complete)
  5. #15
    May 2010
    Australia
    Subscribe to this, especially as you are in Vic
  6. #16
    Aug 2009
    Melbourne, Australia
    I am from Vic as well,
    Had a full setup in a VX S Pack but just finnished striping it out for a new install in the VE SSV just purchased.
    I am sure I can help if you need any!
  7. #17
    Apr 2007
    thank you.
    I will be hopefully finishing the diagram by the weekend and I am open for suggestions and revision.
    Basically after the drawing, it's just a matter of making sure I have the hardware and then build build build!
  8. #18
    Apr 2007
    I did some research and I have found that the Joycon module is compatible with the steering wheel buttons
    some info that might help from another forum:
    To ensure you have the right brown wire, with the car off, put one end of a multi meter into the brown wire and the other to ground, and push each button, you should measure:
    NOTE FOR VY/VZ: Ensure you have the black/yellow wire earthed or the resistances will be incorrect.
    •Mode = 21.78K Ohms
    •Next UP = 11.78K Ohms
    •Next Down = 7.03K Ohms
    •Mute = 3.7K Ohms
    •Vol UP = 1.4K Ohms
    •Vol Down = 1.9 Ohms
    •NOTHING PUSHED = Infinite Ohms
    •Mode = 1.47K Ohms
    •Next UP = 790 Ohms
    •Next Down = 460 Ohms
    •Mute = 280 Ohms
    •Vol UP = 160 Ohms
    •Vol Down = 80 Ohms
    •NOTHING PUSHED = 3.66 KOhms
    this is the controller which I just purchased : http://www.ebay.com.au/itm/CarPC-Joy...item4ab009b682
    btw the carpc has left the US and should be with me very soon!
    I received the GPS receiver.
  9. #19
    Apr 2007
    Carpc has arrived!
    also pic of the GPS receiver and monitor
    Hardware gather status: [|||||||| ] 80%
    Wiring diagram status: [||||| ] 50%
    Testing phase status: [ ] 0%
    Installation status: [ ] 0% (starting during the xmas holidays 2011)
  10. #20
    Nov 2011
    Warwick, Queensland, Australia
    Sub'd ....even if it is the wrong badge;-)
  1. 2004 VY Holden Commodore Full Install (AU)
    By soyfish in forum Worklogs
    Last Post: 06-22-2010, 06:36 AM
  2. Holden Commodore VSII Carputer
    By harmer56 in forum Worklogs
    Last Post: 10-17-2007, 07:48 PM
  3. Holden VS Commodore Carputer Finished
    By XtremeX in forum Show off your project
    Last Post: 12-22-2005, 05:19 PM
  4. Holden VL Commodore -> MP3IAN MkII
    By MP3IAN by Ian Gregory in forum Show off your project
    Last Post: 11-09-2002, 11:46 PM
Tags for this Thread
