fiberglass has always been a good solution for me, with a little practice and alot of sanding, it can be done with perfection, just remember bondo is only good as a filler and to fix imperfections do not try to mold your whole screen bezel out of bondo alone, if you do make sure you cover it with fiberglass or another harder compound or you will end up with a cracked, broken piece of garbage.
another way to do it would be to "weld" or melt the plastic pieces together then sand to a smooth surface adding plastic where it is needed to accomplish the smooth surface...
LinkBack URL
About LinkBacks
