Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: BMW e81 1series 56k warned!
  1. #21
    Mar 2010
    Sent you a pvt msg, but i suppose i should rather make it public?
    Hi. I got the same car as you(E81 1 series), I really like the oem screen (bmw housing)
    How much did you pay for it? Where i live from bmw they Want $3000 for it....
    Also, do you have a part number for it? or is it the same as E87?
    http://global.ebay.com/BMW_1er_e87_C...389267554/item
    is this it?
    and did you have to modify alot of it to fit the touch screen? or perfect fit?
    also is it not to far to touch it? like to far forward......?
  2. #22
    Aug 2009
    Quote Originally Posted by brukutu View Post
    is this it?
    the screem was OEM, I pay 80€ at ebay.de, now I's a little bit expensive, I think.
    -needs a modification to fit the new screen, but It's easy; it oly takes you 15 minutes.
    -yes It's a little far , but I also have a space navigator joystic like the oem iDrive.
    you're gonna love this link:
    http://cgi.ebay.de/Original-Central-...item230691f2f5
  3. #23
    Mar 2010
    Question
    Quote Originally Posted by krolinx View Post
    new moification, motorized screen:
    Inns't the screen motorized by default?
  4. #24
    Aug 2009
    yes it isn't.
    It's only only default on oem navi.
    anyway it's easy to do, ask me when you need it.
    Did you consider other option to have gps?
    cheaper and easyer:
    http://www.1addicts.com/forums/showthread.php?t=286884
  5. #25
    Mar 2010
    Do you think they will ship it to South Africa?
    Omw thanks for the find.
    How come i am finding them for 500 euros+ ? ppl buy them for like 60 ? i dont get it. what am i doing wrong?
    so you said, it is not motorized ?
  6. #26
    Aug 2009
    who knows..... bu ask the seller, probably they will
  7. #27
    Mar 2010
  8. #28
    Mar 2010
    I am going out now. Thanks will keep in touch.
    cant understand german thou....
  9. #29
    Mar 2010
    Motorized
    yes it isn't.
    cheaper and easyer:
    How did you do the motorized screen?
    also will any 7'' screen fit nicely in there? like a liliput?
  10. #30
    Feb 2010
    Since i did the same mod with 7"&BMW CID(FLIPUP)@E87 i can provide some info too =)
    Well there are to options.. remove the 6 pin connetor (using only 4 btw) and solder these wires directly to your radio or. buy the connector & cables (part nr. 61 13 6909058 + 61 13 0006663 (4x))
    flip up plug: -> radio plug
    pin 1 : terminal 30 (plus) -> Radio = pin 15 (red/green - thick cable)
    pin 3 : terminal 31 (minus) -> Radio = pin 12 (brown - thick cable)
    pin 5 : K_CAN High -> Radio = pin 11 (orange/green)
    pin 6 : K_CAN Low -> Radio = pin 9 (green)
    Of course do not remove the PCB inside because you need it for flip ofcourse.. just the lcd =)
    More info with pictures on this link http://www.1addicts.com/forums/showthread.php?t=286884
    & It will fit but you won't see the whole screen because the original inside is only 6.5" you can cut the bezel(sand it) or just use a custom resolution in centrafuse(like me).
  1. BMW e39 5 series build started....56k beware!
    By lewisdg in forum Show off your project
    Last Post: 12-17-2009, 07:27 PM
  2. Replies: 13
    Last Post: 03-19-2009, 08:57 AM
  3. Usb/audio interface for bmw & valentine2pc interfaces
    By Mattlocked in forum Classifieds
    Last Post: 02-18-2009, 06:33 AM
  4. Seafoam (56K consider yourself warned)
    By lgbr in forum Off Topic
    Last Post: 05-17-2005, 03:05 AM
