Yes that is why cars that run on LPG have a converter that converts the gas into a vapor. After the passing though the converter its piped to the throttle body and is dispersed through a mixer. The mixer acts like a venturie, so the air passing through the mixer ring draws the gas out of the mixer and supply's the engine with a air/gas mix.
Problem with this setup is its like an old carby setup and the liters per hundred (fuel consumption) is poor compared to petrol.
Now with the LPG injection I mentioned. The liters per hundred is equaled to petrol and more power is gained. There is still a converter in the setup to convert the liquid into a vapor, But its the separate ECU that I am interested in.
This ECU is fully programmable so you can tune it once the supercharger or tubo is fitted (have not decided witch way to go yet).
Im also aware of how LPG tanks are only filled to 80% of there compasity.
Speaking of tanks I have recently picked up a new stainless steel LPG tank witch I will be replacing soon.
LinkBack URL
About LinkBacks
