Most are trucks (that are converted tank in bed) so no danger of the tank popping off and filling the "boot" with gas due to heat. You are correct not many cars or trucks for that matter here (USA) that I see converted to propane. If LPG is as common as you say then the tank you purchased is probably "boot ready" and you shouldn't have any problems. I am a service tech for a propane co. here and you would be shocked at the crap I see. I am only concerned with safety(your and others). It sounds as though you have all your ducks in a row.
A vaporizer is a carb of sorts. I thought you were using direct injection. It's like fuel injection but, propane is is ran through a heater (heated by the radiator core) to prevent it from freezing up. The vaporizer take liquid and "vaporizes it then it goes to the intake to the cylinder. It to has a line from the radiator to keep it from freezing.![]()
LinkBack URL
About LinkBacks
