Hi Rob,
Having just finished installing my CarPC with very similar components. i believe i am in a good position to answer some of your questions.
The barrel connector on the case is to power your monitor using a wire with 2.5mm barrel plug on both end.
The 6 pin harness as in your 1st picture, one end connects to the M2-ATX while the other end connects to the M1/M2/M3-atx power adaptor (You may need to crimp the ends of your wires).
The AC/DC switching adapter is then connected to the barrel end of the M1/M2/M3-atx power adaptor.
I hope that make sense.
LinkBack URL
About LinkBacks
Yes, in someplaces of China, worklogs are also in worklog forums....
