Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2004 Mitsubishi Lancer Ralliart
  1. #11
    Mar 2007
    Maryland, for atleast 3 months, then VA?
    2004 Ralliart Project Post
    Started a thread on my car
    2004 Mitsubishi Lancer - Ralliart
    2004 Mitsubishi Ralliart Lancer
    Lilliput 619 7" Touchscreen
    EPIA MII-12000
    512 MB RAM
    160 GB 2.5" Drive
    Black VoomPC Case
  2. #12
    Low Bitrate dvwjettaiii's Avatar
    Jun 2005
    Neenah, WI
    I found some time today to start cutting out some more space in the stock center console. I had to make it slightly wider than the DIN hole already in there, and then cut it up to leave about 1/2" of plastic along the top.
    Cut OEM center console
    Recycled Lilliput bezel from last project
    Stock console piece in place in the car
    The Lilliput bezel will be angled to reduce glare and to provide enough room for the back of the monitor assembly to fit.
  3. #13
    Jun 2005
    Neenah, WI
    I rough sanded the entire screen bezel and the top half of the console piece to better hold the fiberglass, then masked off the outside area.
    I used the big piece of masking tape down the middle to hold up the bezel while applying the fiberglass.
    Fiberglass applied to the bottom and lower half of the sides. I'll give it 24 hours to dry and then work on the top half.
    I finally got some summer tires with some used wheels, so here's what the outside is looking like now.
  4. #14
    Jan 2008
    Any progress recently? Let's get some pics up!!!
  5. #15
    Jun 2005
    Neenah, WI
    Well, it's put together. Running CF, with iGuidance with no problems. But when it comes to adding plugins and getting the HD radio to work with my serial-to-USB adapter I'm pulling my hair out! I've got so many problems that I'm working on right now that I'm not going to list them. I'm just spending time reading other threads, but then again I've been doing that for weeks now.
  6. #16
    Low Bitrate agentq's Avatar
    Nov 2010
    Escondido, CA
    Im in the middle of my 06 evo mr computer install.
    Im putting in a 8 inch lilliput, but I would recommend buying the 2din oem mit bazel, then just relocating the hvac to the bottom cubby.
    http://forums.evolutionm.net/evo-how...e-din-mod.html
  1. 2004 Lancer, wanting to build, but portable.
    By tallicdeth in forum General MP3Car Discussion
    Last Post: 09-23-2009, 01:32 PM
  2. 2004 Mitsubishi Lancer LE Car pc Installed Bangalore India
    By mpsreejesh in forum Show off your project
    Last Post: 04-12-2009, 10:06 PM
  3. 2004 Mitsubishi Magna VR Car PC
    By MitchellO in forum Worklogs
    Last Post: 01-01-2009, 12:12 AM
  4. Replies: 3
    Last Post: 08-26-2006, 11:54 PM
  5. Replies: 2
    Last Post: 08-10-2006, 11:43 AM
Tags for this Thread
