Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 99 Grand caravan
  1. #11
    Jun 2009
    London, United Kingdom
    Sell it and get an old POS screen, you can get them pretty cheap. I got a 10.4" POS touchscreen for £20 (approx $35-40), not got around to using it for anything mind but the touchscreen is responsive, brightness could be better... Good budget choice though...
  2. #12
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Here's a 17-inch system mounted in a Scion xB. It's in use as a daily driver, and works just fine.
    That mount was custom-built, but, since we built that, we've found some very nice tilting systems on old desktop mounts for LCD monitors; many of them might be adaptable to your usage. Almost all LCD monitors and panels use a mount with a 100mm square screw-hole pattern. You might even attach the desktop mount to a custom base attached to the floor or seat rails. Check for non-functional LCD monitors at your local PC shop or Goodwill; tell them you're looking for an LCD panel that doesn't work. Maybe even offer them a few bucks for the right one; otherwise, they'd probably put it in the trash.
    One other thing: you'll probably want to look at investing in a DC-DC power supply -- like an Mini-box M2-ATX or M4-ATX, or one of the Opus or Carnetix models. Yep, it's a chunk of money, but that inverter will change your fuel economy, and not in a nice way.
    Oh, and one other thing you could consider somewhere down the road: I'm not familiar with the space in the Caravan, but I can see that you have a lot of air in that computer case. If you replace the power supply with a DC-DC unit, you could cut your existing case down in size, or relocate the PC to a much smaller box. In fact, the shell of the case you have would be pretty decent material to make your own box, and you could use the existing mainboard mounting panel as the mainboard mount part of it. You could use some aluminum angle -- not too expensive at Home Depot or Lowes -- to form the corners (pop rivets and pop rivet guns are cheap; check Harbor Freight). Lay out the size you want; eliminate the AC power supply, and move some of the parts around, and you might well fit it into the console or, if you just cut it down, make it so it fits naturally as a console. If you make a new box for it, it might fit under one of the seats.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #13
    Newbie ryan518w's Avatar
    Oct 2009
    Quote Originally Posted by rdholtz View Post
    That mount was custom-built, but, since we built that, we've found some very nice tilting systems on old desktop mounts for LCD monitors; many of them might be adaptable to your usage. You might even attach the desktop mount to a custom base attached to the floor or seat rails. Check for castoffs at your local PC shop or Goodwill; tell them you're looking for an LCD panel that doesn't work. Maybe even offer them a few bucks for the right one; otherwise, they'd probably put it in the trash.
    I like ur setup thats what i was aiming for
  4. #14
    Oct 2009
    Quote Originally Posted by TheGuv View Post
    sounds like a plain if u still have it when i get about $50 I will pm u
  5. #15
    Oct 2009
    The Hoopty
  6. #16
    Jul 2007
    My caravan 03 has a 7" Lilliput monitor, just to the right of the center Vents. works great.
    I use a Evo u510 pc. (between the seats, M2-atx power) that runs a laptop CPU, little to no fan needed. usb-GPS unit on the dash, a wireless 'g' dongle tucked under the head jam trim. I have a very small wired keyboard, and hand held track ball mouse if needed. I used a universal GPS mount for the monitor, fully adjustable and the screw holes for it are behind the console bezel (clean for resale). little hint for a pc in a van on the floor; just stick one half of (the coarse side) of "velcro" to the pc side touching the floor. this stops the unit from sliding. PM me this unit is for sale!
  1. I Own a 99 Intrepid work in progress
    By platinumdjmix in forum General Hardware Discussion
    Last Post: 10-01-2007, 10:14 AM
  2. Replies: 2
    Last Post: 08-11-2006, 10:20 PM
  3. Stock 99 VW Deck -- Wiring
    By MPVW in forum General Hardware Discussion
    Last Post: 05-15-2004, 02:20 PM
  4. Protel 99 Crack
    By Dima in forum Software & Software Development
    Last Post: 01-27-2001, 02:05 PM
