Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 57
Thread: Corsa C Van + Atom + Gentoo Linux + 9" Capacitive touchscreen
  1. #11
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Calculations, measurements, energy
    The idle energy consumption is about 50-53W, up to 70-71W when turning on the pc.
    However, I'm using a 420W power supply, and it eats around 9-10W alone, when the PC is off.
    Also, I'm still using the hdd instead of the ssd, and got a wireless keyboard, wireless usb stick,
    so I think 70W is the worst-case scenario.
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
  2. #12
    Oct 2009
    Budapest, Hungary
    Tip of the day
    If you are using wireless usb keyboard, and it stops working after you boot from
    the linux liveCD / install disk, try a quick plugout-plugin, it will solve the problem.
    Check my worklog:
  3. #13
    Oct 2009
    Budapest, Hungary
    Today's Special
    Kernel
    So, I made a basic kernel < 2MB:
    -using embedded options, removed printk, core dumps, debug info, legacy stuff
    -no serial port, no cdrom, no firewire (I don't need them)
    -no kernel modules
    -very basic networking (I only need net for emerge fetch)
    -removed all security-related thingies, no need of them (no internet connection)
    -added touchscreen and audio support
    Result: some kernel panic first (and second)
    After that, lightning-speed startup.
    Plans to compile with ICC
    USE flags
    Well, the "minimal" USE flag is a crap. Vim is useless with it. xorg-server too.
    I will only use it case of emergency (bloatware). Using a small amount of global
    USE flags, the most of the are package-specific, in /etc/portage/package.use,
    to keep the install small.
    Problems
    Baked touchscreen controller accidentally :S
    Does anyone have one? (3M EXII-7010UC USB)
    Problems with the wireless usb stick, no WPA. Not a big problem (only need for fetching).
    Not very happy with the Intel mainboard, maybe I will go with Gigabyte GA-GC330UD,
    or an other Atom330 alternative, any advice would be appreciated.
    (no zotac ion, power hungry and expensive)
    The main problem with the Intel board is cooling. Gigabyte has 3 heatsinks (NB, SB, CPU),
    and you can easily swap them with a bigger aftermarket one. Almost the same price as intel.
    Also, more durable (better capatitors, MOSFET, heatsink)
    Audio
    Still thinking about the sound card, now I'm using the integrated Intel HD,
    but thinking about a more audiophile solution (Hippohifi Bloat DAC with RCAfor example).
    Check my worklog:
  4. #14
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by simplex View Post
    . . . Not very happy with the Intel mainboard . . . The main problem with the Intel board is cooling. Gigabyte has 3 heatsinks (NB, SB, CPU),
    I have the D945GCLF2 board, and I wanted more cooling, too. I upgraded the fan and heatsink on the GPU, and moved the GPU fan and heatsink over to the CPU, which previously had only a heatsink. Here's the link to the post where I wrote about it.
    And here's a link to a subsequent post with a closer view.
    Finally, here's a link to the post where I flipped the new fan over (because I had it blowing down when I first installed it -- oops).
    The fan and heatsink I used are similar to the smaller fan/heatsink systems used on processors back in the days of sub-1GB systems. There should be a lot of them around at pretty attractive prices -- or you could pull one from a scrapped machine.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  5. #15
    Oct 2009
    Budapest, Hungary
    Thanks. I'm planning a full-passive system, but the clips that fix the heatsink are useless,
    so it's hard to put a factory replacement copper piece on the board. Also, Southbridge
    could use some cooling too. Maybe I will put a custom-made heatsink on the board.
    Check my worklog:
  6. #16
    Apr 2007
    Atlanta, GA, USA
    Thanks. I'm planning a full-passive system, but the clips that fix the heatsink are useless, so it's hard to put a factory replacement copper piece on the board. Also, Southbridge could use some cooling too. Maybe I will put a custom-made heatsink on the board.
    I see -- you're headed in the opposite direction: no fans, instead of more fans.
    I agree that the clip mechanisms that hold the heatsinks are minimalist. I really had to do some tricks to bend up the wire to hold the new heatsink on, but I got it done. I didn't even try to add a Southbridge cooler, expecting that the airflow generated by the two fans should keep that cool. Passive cooling presents a whole different set of problems.
    My Intel is working well as a carPC. I suspect that, if you decide to go to the Gigabyte unit, you'll find a ready market for your Intel board.
  7. #17
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    a couple questions: what kind of boot time do you expect to achieve with your custom kernel? What kernel version? What audio software? Why not nGhost? Why not LinuxICE?
    -Cheers
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  8. #18
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Do you expect your system temps to be high?
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  9. #19
    Dec 2007
    AZ
    Quote Originally Posted by kev000 View Post
    -Cheers
    Curious, is nGhost in Portage or has it been built and tested from source on Gentoo?
  10. #20
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by hexxamillion View Post
    nGhost is not in portage afaik. There is an ebuild file in svn though.
  1. Replies: 8
    Last Post: 11-06-2009, 01:45 PM
  2. BMW with OEM linux Atom system !!??
    By bes51659 in forum General MP3Car Discussion
    Last Post: 08-29-2008, 11:11 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Linux or Window$$
    By Psychobiker in forum General MP3Car Discussion
    Last Post: 02-17-2006, 09:45 AM
  5. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 10:12 PM
