Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 57
Thread: Corsa C Van + Atom + Gentoo Linux + 9" Capacitive touchscreen
  1. #21
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by kev000 View Post
    a couple questions: what kind of boot time do you expect to achieve with your custom kernel? What kernel version? What audio software? Why not nGhost? Why not LinuxICE?
    -Cheers
    I dunno the boot time now (still doing emerge -eq world, forgot to add some cflags),
    but the bottleneck is the init system now, the time between the bootloader and the start
    of init is negligible.
    Using gentoo-sources-2.6.30-r8, will add some stuff to work with ICC.
    Benefits of using ICC over GCC for an Intel processor are obvious I think (+10%-40% speed)
    I'm planning to use a very basic audio software with mp3 and flac support.
    I'm using gentoo and custom build apps because I don't like apps that just work
    I want challange, and small benefits from huge efforts
    That's why I'm messing with an 8-year old car instead of buying a new one.
    Quote Originally Posted by hexxamillion View Post
    Do you expect your system temps to be high?
    I have no A/C in the car, summers are hot here, and passive cooling is more reliable,
    and also, saves some power.
    EDIT: switched to 32-bit from 64-bit, to keep multilib issues out (I need 32-bit because of Igo8)
    Anyway, everything has better support on 32-bit, for example, compiling kernel with ICC is very
    easy now, thaks to guys from LinuxDNA.
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
  2. #22
    Oct 2009
    Budapest, Hungary
    Layer 8 issue
    Successfully migrated to gcc-4.4.2 from 4.3.4. (emerge -eq world)
    Had some minor problems (user error), wasted two days because of
    typos in use flags, cflags, etc. (I started the install at 7:30 and then go to work,
    emerge failed at 7:32)
    Installed icc-11.1.056 too, I'll play with compatible packages & kernel in the afternoon.
    Will post make.conf and /etc/portage/package.* (hopefully).
    Need to emerge life, too
    Check my worklog:
  3. #23
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by simplex View Post
    Layer 8 issue
    Gotta love them USE flags
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  4. #24
    Oct 2009
    Budapest, Hungary
    Bad news
    Got a little accident, right mirror gone :S
    No problem, always wanted electric mirrors, no fancy M3 of that kind of stuff,
    I'll go with a factory one, I makes the car unique, as everyone using M3 mirrors
    on their corsa here
    Check my worklog:
  5. #25
    Oct 2009
    Budapest, Hungary
    Audio and Interior
    Weekend coming, so finally, I can work on the audio and the interior (a bit sick of software now)
    Here's the plan:
    -complete sound deadening, approx 100 sq ft (~9 sq m), my final choice is Fatmat Megamat
    -JBL C608GTI components to the front
    -JBL GTO 75.2 Amp, budget spent on the components and deadening
    -custom speaker mounts (Thanks to Coops from opelforum)
    -custom door cards (to fit the new speakers and the electric window & mirror switch)
    -new wiring to the door (added electric mirrors, electric windows, new speaker cable)
    As you can see, no subwoofer and only 2 channel amp. I'll connect a woofer amp to
    the aux out of the GTO 75.2 later, and will add a decent woofer (or three), but only
    when I'm finished with the more important thingies. (again, almost the whole budget
    was spent on the deadening and on the components)
    I'll start with removing the metal trunk floor (standard in corsa van), and replacing the
    metal grille with something, temporary. I must separate the two seats from the trunk with,
    as she's a 'truck', at least in her papers
    It will take my whole weekend, as the trunk floor fitted with headless screws (their heads
    designed to broke off when they screw them in, so it's impossible to remove them at home)
    Check my worklog:
  6. #26
    Oct 2009
    Budapest, Hungary
    Weekend - Day 1 - Weight reduction
    So, I removed the metal trunk floor, the grille and some plastic side panels from the back.
    Result: -45-50 kgs!!! Maybe I'll need new springs, as the back of the car is higher by an inch
    after the weight reduction. Noticeable difference in acceleration.
    Pictures:
    Removed some plastic, to reach some screws
    I needed a drill and a flex grinder to remove the screws
    Can you see the dust and the metal chip?
    Finished, now time to clean
    Check my worklog:
  7. #27
    Nov 2009
    3M EXII-7010UC USB connector cable
    Hi, i got the capacitive touch screen after checking you thread. It a very cool project you got going.
    can you suggest where to get the 3M EXII-7010UC USB connector cable from? I am modding a dell mini 9 to be a touch screen tablet with gps and accelerometer.
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    What driver are you using with the capacitive touch? Where did you get it?
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  9. #29
    Nov 2009
    i got it from ebay, from the link that simplex posted on his 1st or 2nd post. I dont have a cable to connect the touch screen controller to USB. Until then i donno what driver to use.
  10. #30
    Oct 2009
    Budapest, Hungary
    Well, about the cable, I made one from an old USB cable (careful with polarity, you
    can burn the panel or even the mainboard)
    Linux has support for Cleartek/Microtouch touchscreens, as far as I remember,
    it's in the kernel config somewhere in the Input devices or HID devices or USB area.
    Well, atleast in gentoo-sources.
    Check my worklog:
  1. Replies: 8
    Last Post: 11-06-2009, 01:45 PM
  2. BMW with OEM linux Atom system !!??
    By bes51659 in forum General MP3Car Discussion
    Last Post: 08-29-2008, 11:11 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Linux or Window$$
    By Psychobiker in forum General MP3Car Discussion
    Last Post: 02-17-2006, 09:45 AM
  5. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 10:12 PM
