Page 6 of 6 FirstFirst 123456
Results 51 to 57 of 57
Thread: Corsa C Van + Atom + Gentoo Linux + 9" Capacitive touchscreen
  1. #51
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Simplex is back! I had some work, but now I'm free again
    Wiring
    The car has some problems (P0560 error code), when the engine is not running,
    but the ignition is on, the BCU only got 0.5V. I wanted to swap the dash wiring loom anyway,
    so no problem
    Plans (suspension)
    -175/65r14 tires, because of the crappy roads and for better economics
    -35mm H&R springs
    -H&R anti-roll bar
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
  2. #52
    Oct 2009
    Budapest, Hungary
    Wire in the hole!
    So, I swapped the wiring, from factory crap to central locking+electric windows/mirrors one.
    Suddenly, the P0560 code disappeared
    Added some mechanical protection to the new loom, to avoid situations like this
    Some pics:
    The old loom
    The new one
    Also, working on a new security system, with protecion film on the windows,
    custom home-made 3-point immobiliser, etc.
    We need better security if we want to put in an expensive carPC, and a "Hey, steal me!" sytle
    9" touchscreen. Many forgot this, and found his car with a broken window, and without the
    expensive carPC/audio stuff.
    Also, thinking about shaving the door handles, but in a reversible 'bolt-in' way
    Check my worklog:
  3. #53
    Oct 2009
    Budapest, Hungary
    Progress - Quick post
    Added electric trunk door popper, and plenty of butyl-rubber goo in the trunk/rear wheel arches.
    Working on the door cards, for the speakers.
    Messing with gentoo init system.
    Will add some pics as soon as I'm free
    Check my worklog:
  4. #54
    Oct 2009
    Budapest, Hungary
    No more noise
    So, I added some dynamat to the trunk area, I will do the same with the doors, firewall,
    front wheel arches, etc. Also, planning to add some secondary noise reduction, something
    cheap, but effective over the dynamat coating.
    Some pics:
    Almost complete
    Work in progress, also, some extra wiring
    Check my worklog:
  5. #55
    Oct 2009
    Budapest, Hungary
    Interior
    Some improvements done on the car's interior:
    New seats
    Fitted the triple-info-display
    I painted some parts of the centre console, to try how it looks in black,
    unfortunately, the paint was glossy, but I will add some kind of matte black
    coating material on it later, so I don't care.
    Swapped the interior light bulb to LEDs (1/8 drain, 10x brightness)
    ...pics coming soon...
    Check my worklog:
  6. #56
    Oct 2009
    Budapest, Hungary
    ICE-ICE baby!
    I need some extra wires into the doors, as the ones one the original loom are too thin for
    the electric windows, speakers, etc...
    I don't want to drill an other hole on the door, so I hacked the original connector
    Not the best quality, but you can see the 3 holes
    The new switch for the mirrors+windows
    The electric window motor
    Also, I'm working on some custom speaker mounts for my JBL components, they are too
    big and heavy, the standard 165mm speaker adapter is useless in this case.
    Size matters
    Check my worklog:
  7. #57
    Oct 2009
    Budapest, Hungary
    Boot
    Wired the electric boot popper, small effort to make my car more comfortable
    Some additional wires and the solenoid
    New keyless handle from an Opel Meriva, color coded
    Check my worklog:
  1. Replies: 8
    Last Post: 11-06-2009, 12:45 PM
  2. BMW with OEM linux Atom system !!??
    By bes51659 in forum General MP3Car Discussion
    Last Post: 08-29-2008, 10:11 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  4. Linux or Window$$
    By Psychobiker in forum General MP3Car Discussion
    Last Post: 02-17-2006, 08:45 AM
  5. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 09:12 PM
