Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
Thread: Corsa C Van + Atom + Gentoo Linux + 9" Capacitive touchscreen
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Car:
    Bought an 2001 Opel Corsa C Van 1.2 for cheap, now upgrading.
    Working on the engine, exterior, interior and on the audio system parallel with the pc.
    Mechanical mods
    -plans to put in a Z18XE (125 bhp) or Z20LET (197 bhp) paired with new brakes and suspension.
    Interior
    -redesigning in a black/red/silver theme
    -modifications are needed for the component speakers and for the touchscreen
    Audio
    -planning: component speakers, sub, amp depends on sound card / dac
    Hardware
    -9" custom built sunlight readable screen with 3M capacitive touchscreen
    -Intel D945GCLF2D & Intel Atom 330 1.6Ghz - working on custom cooling fan
    -2GB RAM
    -16 GB SSD, but using a 40GB SATA HDD until final assembly
    -Looking for a decent sound card / DAC
    -Currently running on my desk with a 420W power supply
    Software
    -Gentoo Linux, fully optimized, will be cleaned up before the final assembly
    -Custom written frontend/window manager integration
    -Igo8 with wine
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
    Oct 2009
    Budapest, Hungary
    Testing on desk - Installing Gentoo
    Working on my TV with wireless desktop. Using USB-stick for temporary wifi access.
    I will add detailed info about the install when it's done, now pictures:
    I didn't had a smaller display in my room
    A little messy, but working
    Check my worklog:
    Oct 2009
    Budapest, Hungary
    Custom 9" capacitive touchscreen - Part 1
    Plan
    Replace the old CCFL backlight of a cheap TFT with automatically adjustable LED backlight ,
    and add a capacitive touchscreen to it.
    Ingredients
    9" tesco value 12V vga screen, made in china
    3M capacitive touchscreen with usb controller from ebay ($39)
    LEDs, with an adjustable circuit (in progress)
    Part 1
    So, first, I stripped my "reasonably priced" screen a bit, removing some parts:
    -the case
    -speakers
    -the high-voltage backlight panel
    Stripped
    Then I realized, that I don't need the front panel with the remote infra led and the buttons
    Also, I taken apart the TFT panel, and removed the backlight (and temporary, the filter/mirror sheets under it)
    Now, we are going somewhere...
    So, now i have the TFT with it's circuit, the controller panel, and a panel for the connectors.
    The energy consumption of the screen was 13-14W with the backlight.
    Now, without it, it's almost nothing (<1W), and it's still viewable (a bit) in low-light conditions.
    TODO next time:
    -Remove the connector panel, and attach 12V and 15 pin d-sub to the controller directly.
    -Maybe remove unnecessary from the panel (TV-tuner, AV-in)
    -Add LED backlight
    -Fit the touchscreen on the TFT
    -Make a new case for the TFT with the new backlight and sheets
    -Make a manually adjustable backlight circuit to test
    -Make an automatic backlight circuit (adjusting the luminance depending on light conditions)
    Check my worklog:
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Cool. So what apps or front end you installing on Gentoo?
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Oct 2009
    Budapest, Hungary
    No apps, no frontend
    I'm using linux in my project because:
    a) I'm a gentoo geek
    b) I want performance
    c) I want custom UI and programs that satisfy my needs
    My needs are:
    -Audio (using the pc as a DSP)
    -GPS
    -maybe OBDII info
    Setup
    Simple minimal Xorg setup, USE flags staring with "-*"
    Using ICC as compiler where possible.
    Window manager/frontend
    I start off from DWM code, and add
    multitouch gestures, an audio player integration, and a wine integration (for Igo8) to it.
    When it will be safe & stable, i'll release it to the community.
    Phase 1
    Install a basic gentoo system, test the WM, optimize, remove things that will be
    a problem later for the SSD (disable swap, portage in tmpfs, etc).
    Strip programs used for testing/compatibility.
    Make a documentation of the system.
    Test it in the car 'til it works.
    Backup (this is the backup for upgrading the system)
    Phase 2
    The finalized installation will contain alot of garbage.
    (unneded programs, config files, gcc, portage, source code, distfiles)
    So I need to strip/reinstall the whole thing with the final config files and programs.
    Backup (this is the system restore backup)
    Phase 3
    Disconnect the HDD, connect SDD, copy backup on it.
    Set /etc/fstab and others to live happily with the SSD.
    Put it in the car.
    Check my worklog:
    Dec 2007
    AZ
    Quote Originally Posted by simplex View Post
    My needs are:
    -GPS
    -maybe OBDII info
    Setup
    Simple minimal Xorg setup, USE flags staring with "-* minimal"
    Phase 1
    Phase 2
    Phase 3
    Put it in the car.
    Gentoo is good. I've used it in the past. As far as I'm concerned Redhat,Gentoo or Debian work well for me. It's nice to see more LINUX users in here. Although I feel like a traitor using Windows 7 this time in my project.
    Oct 2009
    Budapest, Hungary
    Gentoo is like women.
    Altough she looks very simple to use, she can bite your head off for the smallest mistake.
    The mistakes of the past will come up in the worst moment, suddenly
    And, it doesn't matter how you deal with her, softly or hard,
    her reaction will be total random
    latest example: forgot to add xml USE flag for python, didn't give a ***** about
    the warning (there were no blinking red lights or something like that), system ruined
    Windows 7 is nice, I'm using it on my laptop (I need MS stuff for my work).
    Check my worklog:
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    she's reaction will be total random
    the warning (there were noblinking red lights or something like that), system ruined
    Good comment -- got a laugh out of me (at the metaphor, not the tragedy).
    Going with your sig, "My english is crappy, please correct me ", I'll make one correction: change "she's reaction will be total random" to "her reaction will be totally random".
    And one comment: your english is far from crappy. Good job, overall.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Dec 2007
    AZ
    LOL! Funny. Yeah gotta be careful with the USE flags.
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by rdholtz View Post
    Corrected, thank you
    Check my worklog:
  1. Replies: 8
    Last Post: 11-06-2009, 01:45 PM
  2. BMW with OEM linux Atom system !!??
    By bes51659 in forum General MP3Car Discussion
    Last Post: 08-29-2008, 11:11 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Linux or Window$$
    By Psychobiker in forum General MP3Car Discussion
    Last Post: 02-17-2006, 09:45 AM
  5. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 10:12 PM
