Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: BMW e36 328i Sport Coupe
  1. #11
    Newbie SCIONology's Avatar
    Dec 2009
    Hickory NC
    i have a question about your psu, i'm about to get a m350 case and m2-ATX psu
    i can't really tell by pics where you mounted the psu.
    i was wondering if there's room inside the m350 case for it, or if you had to mount it externaly
    thanks
    Scion xB G2
    Planning: [----------]
    Parts: [----------]
    Install: [----------]
    My Scion PC Project (put on hold until I find a nicer host):
    Worklog
  2. #12
    Jan 2009
    Quote Originally Posted by SCIONology View Post
    thanks
    Hi there,
    The PSU is mounted next to the Car Stereo on the bottom shelve (you can see it in the photos of the boot). I did try to see if I could mount the psu in the M350 case, but I couldnt find anywhere I was happy with to mount it. I do have limited space in the case due to putting a dual-core atom in and having to mount a fan on the heatsink.
    (see my photos of the case & mobo) It is possible that if you moved the HD mounting to over the side with the CPU and get the optional HD mounting, attach the PSU to that it may all fit.. however im not 100% sure I would 1.. want my HD over the CPU and 2 want the PSU inside the case.
    Maplins to do a project box that the PSU will fit in, which I will be using when I build the shelves correctly.
    HTH
    Lucan
  3. #13
    Dec 2009
    Hickory NC
    thanks for that info, i'll just do something similar, maybe a radioshack project box lol.
    i would just use the m3, because the m350 recommends the picopower, buy this intel mobo requires the extra 4pin power connector by the cpu.
    Scion xB G2
    Parts: [----------]
    Worklog
  4. #14
    Constant Bitrate vull's Avatar
    Oct 2007
    bigger pictures or ban
  1. BMW E36 MF Steering Wheel Retrofit
    By Enforcer in forum Input Devices
    Last Post: 07-09-2010, 09:17 AM
  2. bmw e36 obd II to car pc ?
    By koko in forum Newbie
    Last Post: 01-03-2008, 01:58 AM
  3. BMW E36 coupé
    By Frits in forum Show off your project
    Last Post: 08-06-2006, 03:08 PM
  4. lilliput 7" vga in bmw e36 coupe? HELP!!!
    By rockyfozz in forum Newbie
    Last Post: 08-05-2005, 06:42 PM
