Hmm... well you've certainly given me some good insights here...
I'm planning to have the 12V-9.5V DC-DC Converter with an inline 5A fuse hooked up to a 12V source that is switched on with the ignition in the on/Acc position. This way the converter will charge the Eee's battery when the ignition is on, and the Eee can still run off of battery when the ignition is off, but it just won't be charging, and I don't think I'll have to worry about discharging the battery this way. Once I'm done using the computer, I can send it into hibernate with another push of the Eee's
power switch or by using the on-screen commands. For short errands I can even leave it on or put it into standby instead of hibernate.
In hibernate, the battery should hold a charge for well over a week. Also, if I forget to shut it down, it will just automatically go into hibernate when the battery is too low, but shouldn't drain the car battery either because the charger will be off.
VW's already have a nifty spot by the fuse box to access your ignition-on 12V source as well:
Note: the Yellow/Black Wire marked "75X" is an Ignition-On switched 12V source
This is where I plan to "T" off for my
laptop battery charger (12V->9.5V), my Auxiliary CPU/Case fans, and the PAC IR-X.
