You might hook a speaker or a set of headphones to the Audio Out port, and listen for beep codes.
Since it works with the lid off, try starting it with the lid off and the P4 cable disconnected. See if you get the same condition as you do with the lid on and the P4 cable connected. If it's exactly the same result, it could still be the P4 cable.
Or maybe not . . .
Try turning the P4 cable end-for-end to see if one of the connectors is flaky and reacting to the bending of the cable. Do the same with the ATX cable.
Could a cable be pushing the memory out of place?
Next, use some scrap sheet metal and build a half-lid. Mount the PSU just as it is on the full lid (I wouldn't bother with the fan -- unless it's dead shorting or moving something, it probably isn't the source of your problem). Then you'll be able to see in through the open back half and see if anything looks odd.
Just increase the lid holes where the fan itself is. Don't drill any other holes in the lid. That keeps the air blowing out of the fan from going right back into the case. It's best to keep the inlet and outlet as far apart as possible so you get good consistent flow. Plot a path from your inlets to your fan; the bulk of the airflow should be over the components that are the greatest heat sources. Make sure the air has a place to go when it's installed in the dash; you may even want to position a fan in the dash to blow air onto or away from the PC.
LinkBack URL
About LinkBacks
