Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 146
Thread: 2008 Impala SS - The Connected Car
  1. #111
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Just ordered one of these:
    from here
    It'll be under a "pay as you go" plan which I'll probably do the 300MB for 30days at $20. I don't think I'll go over 300MB but we'll see.
    This will allow both PCs to be connected together (assuming it's a true access point) and allow internet access for both. Anyone know if this is a true access point? If it is, I'll be able to avoid using the ethernet port on the sheeva which will reduce my power consumption by quite a bit.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  2. #112
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    A new direction...
    So after much thought (and accidentally blowing away the filesystem on the sheeva), I'll be going a slightly direction with my setup.
    I knew upfront that it was less-than-optimal because I would still have to use two boxes. Yet I couldn't find hardware that would perform the media functions of a carpc (which i currently used a zotac ION to accomplish) *and* have the low power requirements of the sheeva. I was thinking on going with a beagleboard. But with only 128 RAM and 256mb Flash, I was discouraged... that's not a lot to work with. The gumstix board has twice as much RAM, but that still isn't a lot to work with.
    Times have changed... A user on the Openice forum pointed me to this device which he was trying to run nGhost on:
    This is 720MHz, 512mb RAM and Flash! It's the bigger, stronger, faster brother of the beagleboard and still only consumes ~2W! That's less than the sheeva! It also does OpenGL ES 2.0 and can do 720p video without much effort.
    So lets do a little math:
    sheeva $99
    zotac ION $180
    power supply $60
    RAM $50
    Touchscreen $240
    Total wattage: 6-30W+
    Total Cost: $629
    Now:
    igepv2 $180
    psu $60
    Touchscreen $240
    Total wattage: 2-3W max (not including touchscreen)
    Total cost: $480
    It's also worth noting that ARM processors can go into idle states at 0MHz and draw only 15mW or so. This is about what your PC would be drawing when sleeping only this system isn't sleeping!
    So I save money, energy, and trunk space by going with the igepv2.
    PS. the company that makes this will be coming out with an expansion board with GSM/GPRS, 3 pin CAN interface, and video inputs in Q3 2010.
  3. #113
    Aug 2005
    MD
    Quote Originally Posted by tripzero View Post
    Very interesting board. If I understand you correctly, you can now ditch the Zotac and Sheeva in place of this new board and have it running LinuxICE2 24/7 (or until you drive your Impala again)? Also, do you know if this new board has received positive reviews?
  4. #114
    Jul 2010
    There's no miracles. 2-3W will be an extremely slow system.
  5. #115
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by dmiller View Post
    Power consumption doesnt equal a slow system!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  6. #116
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    http://en.wikipedia.org/wiki/Performance_per_watt
    Low power absolutely doesn't equal a slow system, unless you're using Intel chips :-)
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  7. #117
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Yep, it should run longer than the sheeva drawing 1/3 the power. The guy who's been using it in the openice forums likes the board a lot. He's been playing with LinuxICE and even Android on it. I found a wiki page on running MeeGo on it which I'm highly tempted to port my stuff over to MeeGo and just run that.
    This is nearly the same processor as in your droid, n900 and iphone except for slightly faster and more RAM. I don't have much issues multi-tasking, running navigation apps, playing music, etc on my n900. I can't think of any software that I need to run that won't run well on this device. I'm not running anything very cpu intensive.
    Atoms are much more powerful, but not nearly as performant per-watt as ARM (yet). And the DSPs on the ARM SoC handle all the heavy graphic, image, and sound loads nicely so the cpu doesn't need to worry about them.
    Also, to show how small this board really is:
  8. #118
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    WOW.... Nice board... Looks like it's smaller than PicoITX and perform better.
    looking forward to next update
  9. #119
    Jul 2010
    I have the newest Atom, and I wouldn't call it powerful. It doesn't keep up with 2 gps and music at the same time.
    For $80 its a nice bargain.
    I like the i3, board, and memory for about $250. That runs everything but still idles near Atom's power level.
  10. #120
    Aug 2005
    MD
    Man that is one small board. Thanks for the documentation of your work, I anticipate using your post for my next carPC.
    With such a low power draw, I imagine two or three of these boards could be used to divide up the work load. I'm not sure about Ubuntu, but don't linux distros (in general) work in clusters if configured to do so?
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  2. 1993 Lincoln Town Car Underway (Lots of Pix)
    By Lankin in forum Worklogs
    Last Post: 08-14-2009, 11:08 PM
Tags for this Thread
