So, Sheeva needs 5v and I've got one of those little 12v lead acid batts you see in UPS power supplies. Using that might work pretty well. I think you can deep cycle them and charge them from the car when it is on.
Want to:
Update:
I've got a Zotac ION board and an OCZ SSD drive on the way.
I'm still waiting on the sheeva plug...
Next on the list is the Fusion brain, some relays, volt/current meters and a new powersupply for the carpc. I don't think the m1-atx will power the new board.
I think that I will get this to power the sheeva: http://www.mini-box.com/DCDC-USB
bugbyte, i like your backup battery idea. I'll look into it more. I wonder if I can find a smaller lithium ion batter to use as a backup...
Former author of LinuxICE, nghost.
Current author of nobdy.
The auxiliary battery system is terrific. It means that, with low-power PC systems, we just don't have to worry about the PC eating the main battery. I have three small 7.2A 12V batteries -- sealed lead acid units from a server battery backup device -- wired into the carPC system. I'm running an Atom board: Intel D945GCLF2.
Here's the plastic battery box with the top off . . .
. . . and with the top on:
These pictures were taken while I was still wiring the system up. The battery box sits under the passenger seat (which was removed when I took the pictures).
I've left the system running in the car all weekend, and it was still running Monday morning. I haven't done long-term testing to figure out exactly how long it would operate just on the batteries, but all the evidence thus far indicates that it's a surprisingly long time.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
very nice!
I'm hoping something like this will do the trick:
http://cgi.ebay.com/KINETIK-HC600-KH...ht_4590wt_1167
Wow, at 50A, that definitely will give you some runtime. I have 21.6A among the three batteries in my auxiliary system.
The important factor isn't high power output, but rather the ability to put a little power out over a long period, and to allow deep cycling: deep discharge and subsequent recharge. High power output -- such as a burst of power to start the car -- is what car batteries do well; deep cycle is what backup batteries do best. Deep cycle batteries are likely to have thicker plates.
Just recently I've came to know something about deep cycle batteries. My car has a 72Ah CCA battery, which is a starter battery. I thought deep cycle batteries were something of a golf cart or the extra batteries in an RV. So you can wire those small batteries in the car? Cool.
So when does one need to upgrade the alternator? My alternator is rates at 110 amps at 5600 rpm, and about mealy 19amps at idle. So if I add something like 25 to 50 amps deep cycle battery, will it keep up with that?
Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
Skin: MetroSex on the Beach preview
07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
Well, we're driving Scion xBs, with standard Toyota alternators on 1.5L engines. I have 21.6A of storage, and Josh has a second standard-size automotive battery -- an Optima -- in his (plus a full PC with a multi-core processor). Neither of us needs another alternator.
Thanks!! Very useful info! I think I'm going to buy that one linked above from ebay, or a smaller one, if I figure out where to put it.
I'd like to keep my car in sleep mode as long as possible, and wake it up through 3g and maybe IM it, track it, etc.
WOW, This looks like its going to be a cool project. So basically you will have to use GPS and what not so it know where to do things? Also, how will the car know your coming up to it? Will you have a dongle that senses getting close to it? Similar to like what BMW does? I will note that its not solid. Basically when the car senses the dongle it allows you to start the car, but when you leave the car, it shuts off. I guess the dongles had a long range because there have been times I have told my friend the car is still running. Other issues Ive had is when I borrow his car, to get the thing to start is a b!+ch. I keep telling him that with all the steps, I could have turned a key and been half way down the street. Other then that its fairly good.
About the battery, I am installing a separate alternator for a second battery that will power the car PC and amps, I can use the battery u've picked out, like can it be used on its own, or does it have to be used in conjunction with the normal battery?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
