Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 146
Thread: 2008 Impala SS - The Connected Car
  1. #51
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by OldSpark View Post
    Ignition controlled relays etc is not a recommended practice as you know....
    . . . no, I didn't know that, and what you said sure gets my attention. What's the reason it's not recommended?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #52
    Raw Wave
    Nov 2009
    Within the context (of coarse!) - meaning ignition switch controlled only.
  3. #53
    Newbie govee's Avatar
    Dec 2009
    Southern, Maryland
    Just read an article for the first upgrade for "The Connected Car"....
    Marvell has a quadcore Plug the are showcasing at CES. Lots of processing power added.
  4. #54
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Quote Originally Posted by govee View Post
    Yes, with built in wifi, bluetooth, and a 1.8" hard drive. Plus some other gubbins. But it means that you can use bluetooth GPS and OBDII dongles with zero hassle, which can only make obdgpslogger easier. Next up, replacing the drive with a 1.8" SSD...
    I ... must ... have one.
    Gary (-;
    PS If you're at CES, you'll likely find me spending a lot of time near the Marvell booth. Look for the tall balding guy with long hair and an English accent
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  5. #55
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    And now, for a case.
    Seems appropriate to put all this gear in a case. So i picked up a broken amp on ebay for $20. I should be able to fit the sheeva, fusion brain, wifi and bt in this case with hopefully some relays and other sensors. I want to also utilize the amp's existing connector jacks.
    Here's some pics:
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  6. #56
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Good idea!
  7. #57
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    fun with epoxy
    Mounted some standoffs using epoxy. It seems pretty sturdy, but I'm going to let it dry over 24hrs. Anyone had any experience with this? With the stuff in the amp, everything will be upside down most of the time. Should I be worried?
    Pics:
  8. #58
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    So your replacing a pc with a much smaller solution....that is now the size of a pc
    I did the same thing only reversed the standoffs so that all you need is a bolt. Either way use something like JB Weld and they wont come off without a hammer.
  9. #59
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by justchat_1 View Post
    Oh, this doesn't replace the carpc. this is just an extra, always-on box that will work with the main carpc. Ultimately, I want to replace both with a combined solution, possibly utilizing a gumstix solution like this. Maybe intel will come out with an pico-itx atom that is only 1-5watts and has BT, wifi, and digital i/o.
  10. #60
    Newbie halestorm's Avatar
    Nov 2009
    Quote Originally Posted by kev000 View Post
    There's this: http://www.fit-pc.com
    Dave
    http://www.evalbum.com/2500
    almost no reason to burn gasoline anymore
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  2. 1993 Lincoln Town Car Underway (Lots of Pix)
    By Lankin in forum Worklogs
    Last Post: 08-14-2009, 11:08 PM
Tags for this Thread
